Does somebody know...
Old Aug 31, 2000 | 05:18 PM
andres96SE
...what size of drag tires is the best to get. I took my 96 SE to the race track last week with some 205/50-15 from BF- Goodrich and I couldn't drop my times from 14.8. I know I'm not the best driver, but the problem is that my last best 1/4 mile time was 14.9 without the ECU upgrade and the 235/45-17's on.
Any input??? I called Tire Rack they have the 225/60-15, according to them only one inch smaller than the factory size, compare to the 2 inches difference from the 205/50-15's.
Thanks for any help
96SE,ECU,UD,Y,Fly,Clutch,Cai,Denso
Dynoed 180.6 hp and 207 lbs. of torque at the wheels
Old Aug 31, 2000 | 05:28 PM
Nismo87SE's Avatar
What was your trapspeed?
What kind of trapspeeds were you running? Also what was your 60ft times? I think you want to get the shortest sidewall drag radial that would fit on your rims.
Old Aug 31, 2000 | 05:54 PM
andres96SE
Re: What was your trapspeed?
I don't know what trapspeeds are, but my 60' time was 2.337
Old Aug 31, 2000 | 05:55 PM
98MAX's Avatar
HEHE, I bet your speedometer read
like 105 or somthing, and you must have had some MAD wheel gap. I run on 225/45/16 now. That is a good gear ratio for my auto. If you have a 5-speed and 15 inch rims I would recomend getting like 215/45/15 or 225/45/15 somthing like that. I dont think you need to get drag radials or sliks. I run NOS and I have been running on 225/45/17 and hook up great. You dont want to go to wide, but you want a good foot print. And also play around with the air pressure, that helps a lot too. I run mine at 28psi at the track and I get 2.20 60' with no NOS.
Old Aug 31, 2000 | 06:00 PM
andres96SE
Re: HEHE, I bet your speedometer read
Yes 105 exactly....but those 225/45/17 are a little bit smaller than your factory size, are they?
Old Aug 31, 2000 | 06:07 PM
98MAX's Avatar
well, I forget the math
You can acually figure it out by math, but I forgot it, my rims and tires were a little taller than stock(215/55/16). and a little wider. Your factory rims are only 6.5 wide, I had to keep buying used ****y tires till I found what worked best. Than I bought new ones(hehe) that sucked. Lucky has a tire store and I did not have to pay for mounting and stuff.
Dirksmoothe
Nov 29, 2001 05:08 PM
Ra1max
Nov 29, 2001 07:31 AM
xydavid
Nov 13, 2001 05:48 AM
amsa
Nov 11, 2001 10:44 AM
