Just installed middle section of PR CAI with my exsisting popcharger
MAN...it sounds AWESOME....IMO better than the pop alone OR the CAI alone...I just RIPS....plus I don't fell much of a power loss after 5.5K rpms now.....I LIKE....
Re: Just installed middle section of PR CAI with my exsisting popcharger
I'm waiting for my upper portion form warpspeed, can't wait. I think that this is the single best intake setup out there, and until the frankencar intake comes for the 4th gen, this will be the way to go, IMO.
Nismo1989's selling something similar for 3rd gens. Big 2.5-3" tube replaces the OE intake tract and a popcharger on the end. Pulls hard and sounds good. I'm waiting for mine.
Is the PR tube metal, silicon, plastic or rubber?
-Justin
-Justin
-Justin
-Justin
-Justin
-Justin
-hype
Originally posted by xHypex
The upper PR tube is metal like the rest of the CAI, and you can get it in any color want. Mine is black because my engine bay is all black, but it definitely makes things look cleaner. My only advice about putting in the upper pipe is to go buy a foot of 1/4" radiator hose because the upper part doesnt like to bend after being in the same position for so long.
-hype
-hype
SuDZ
are you talking about the hose that connects the intake to the Idle Air control valve?
-hype
I am just curious how you came to this conclusion?
Thanks bags
Re: Re: Just installed middle section of PR CAI with my exsisting popcharger
Originally posted by bags533
I have had my CAI for almost a year and after looking at dyno plots, cars with and without, and the infamous "butt" dyno I do not feel or see the 5.5 k rpm loss you speak of.
Thanks bags
Thanks bags
Re: Re: Re: Just installed middle section of PR CAI with my exsisting popcharger
Originally posted by Yoritomo
Your butt needs a tune up. J/K heh heh.
Thanks bags
Thanks bags
in every MODDED 4th gen 5-speed I've driven when you wind out FIRST gear there is a VERY obvious drop off in power after 5.5K RPMS....you can only really notice with your "butt" in first because it is VERY apparent...it's like it pulls like hell up to 5.5..and then kind of lets off a little....this phenomonon is pretty much gone after the addidition of the middle section...I'll find out what it does up top on my REAL dyno on Saturday...
Re: Re: Re: Re: Just installed middle section of PR CAI with my exsisting popcharger
Originally posted by MAX2000JP
Im gonna dyno more than your lowly 4th Gen
-hype
Re: Re: Re: Re: Re: Just installed middle section of PR CAI with my exsisting popcharger
good for you....considering you have 32 more hp from the factory....too bad you can't keep up on the street or at the track...
Good thing I am modded then. But I am NOT a 5-speed. So maybe there is a benefit to being an AUTO . Hmmm.... after a little research of the stack of crap I have, I do not have a dyno sheet with your name on it. Do you have one that I could view/download?
I would like to see the comparison as well. Maybe a little something for me to do the next time I am at the dyno. To see how the Auto handles that.
Thanks for the info
Thanks for the info
Thanks for the info
I won't have a dyno until this saturday...at which point I'll post my results....Nealoc187 will be dynoing too....and he has just the popcharger...so comparing the CURVES we'll see if there is less drop off with the cai midsection.
Re: Re: Re: Re: Re: Re: Just installed middle section of PR CAI with my exsisting pop
I'm guessing that at high engine speeds, the stock intake tract creates a lot of turbulence and restriction for the fast moving air. Hence the dropoff after 5500RPM.
Re: Re: Re: Re: Re: Re: Re: Just installed middle section of PR CAI with my exsisting pop
actually most of the drop off is due to the long intake manifold runners on the 4th gen.
Originally posted by dmbmaxima88
you just made a frankencar intake but it cost you like 100 for the JWT and 100 for the PR piece. me=145
We're the ones hyping everything for you :P
-hype
Yeah well if it ever comes out people would be able to buy it
-hype
-hype
Originally posted by PCGuRu2K
I did the same thing with my '01... This setup is even louder then my old setup when I had a CAI... When I go WOT this thing just SCREAMS!!!!
Originally posted by MaxTuner
Hi, did you solve your CEL problem by switching back to JWT??? did you change any new O2 sensors???
Originally posted by Victim64
ummm.. do you have a velocity stack too, or is it just a filter??
tube is slightly longer so it increase the velocity of the air slightly.
