Attn: Those who rebuilt your engines ...
Old Mar 20, 2002 | 05:13 PM
i30krab's Avatar
Turbomax95
Hey Math,
What did you do to your engine when you rebuilt it?? Mine is out and I'm looking for tips. Anyone can join in if they want.
So far I have the 9:1 compression pistons, rings and heavier valve springs from the VQ30DET motor from the Goria Cedric Nissans.
The rods will be beefed and the machine shop will do their thing.
Anything else?
Old Mar 20, 2002 | 05:56 PM
MardiGrasMax's Avatar
I think Mathel also "O" ringed the block to help seal it up under high cylinder pressures.
Perhaps some work in the cylinder head would help, http://www.dpr-racing.com/ Dan Padmore Racing can qouted me $2200 for the full bag of head work, they claimed ~20% hp gain! They have different stages that cost less, but of course gain less power.
a NA supra dyno plot w/ before and after head work plots
http://www.dpr-racing.com/pictures/d...on-turbo-a.jpg
What are you having done to the rods to beef them up?
Old Mar 20, 2002 | 06:16 PM
OriginalMadMax's Avatar
Oh yeah, do the o-rings! I kept blowing head gaskets on my Harley, tried all the types, and with o-rings I got a better seal without any other gasket. Never had another problem. How many angles are you going on the valve grind? The basic is 3, but I know Alfa guys who have 7 angles to improve breathing. 5 is more common; go to thin on your contact surface and they might not last as long.
Old Mar 20, 2002 | 07:10 PM
Maximamike's Avatar
I've heard some very negative things about DPR.
www.theoldone.com
Search "Endyn + DPR"
Old Mar 20, 2002 | 07:22 PM
www.theoldone.com
Interesting about the welding, makes ya think...
Ron, maybe you could have the full porting done with some heat rejecting coatings put on the valves, combustion chambers and piston tops. And you can also get the piston skirts coated with somthing that helps reduce friction.
Old Mar 20, 2002 | 07:45 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
i basically did everything to the motor. pistons, rods, SS valves, springs, titanium retainers and keepers, Oring block, port/polished heads, swain coatings.
You could check out getting yoru heads port and polished. i dont recommend 7 angle valve jobs for a street car. With more angles has more surfaces for carbon buildup and can actually cause lower compression. you could coat your valves and pistons with swain or HP coatings. knife edge the crank for less windage loss but not recommeneded for durability purposes. hummm what else...iron sleeves if you plan to go CRAZY.
Old Mar 20, 2002 | 09:32 PM
i30krab's Avatar
Thanks for the helpful responses guys!
The pistons came from the factory already molly coated on both top and skirts. It takes too long to have the other parts coated.
You're right about the valve Job, I'm going with 3, the 5 or 7 angle are no good for an everyday ride.
I tried to get forged rods but the waiting time is far too long 6-12 weeks depending on the shop! The only thing I can do is have the stock rods shot peaned and polished. This should be fine. I'll also have to change the rod and crank bearings. By the way, did anyone find new bolts to reconnect the heads to the block??
As far as other work, I'll have the reciprocating components balanced and the intake and exhaust manifolds match ported. The heads will just be cleaned up and the cylinder walls honed. Also, I'll have them o ring the block. No knife edging the crank.
Basically what I'm shooting for is 350 hp at the front wheels. this will require a 75 shot of N2O from 2200-4400 rpm. Right now my car is putting out 280 hp at the wheels. I know it can produce more hp as it sits, but Jim Wolf has me tuned on the low conservative side because he won't push the envelope on our cars because of the high boost unfriendly compression ratio. He actually wouldn't touch my car again unless I lowered the compression!
As a sidenote, we broke the bolts and casing on the passenger side axle because of the rust so I sent both axles to NRH tranny in MD where they'll remanufacture them using chromemollie for the axle and spline.
Old Mar 20, 2002 | 09:36 PM
Asian_N02's Avatar
nice to finally hear from you! it seems like the car is undergoing some major work...please keep us updated!
Old Mar 20, 2002 | 09:48 PM
BlkStnValyMaxima's Avatar
I see you guys replace or have pretty much the entire valvetrain done. Do you guys use the stock lifters? Or do you use some other ones?
Old Mar 20, 2002 | 10:16 PM
Head jobs
Yeah, one of my old buddies has one of those boxy looking older Alfa Romeo station wagons, but it's pretty small and tight, and he's cherried it out beautifully. He has access to a machine shop where he used to work, so he can pretty much make anything he wants. That thing has a 4-banger, and he could blow away my bigger 2.5 liter GTV6 coupe! I could finally take him when I got the 3.0 in, but then I blew my trani .... anyone wanna buy an Alfa project car?
Old Mar 20, 2002 | 11:00 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Man... you're doing some crazy stuff. Good luck, Ron!
Old Mar 20, 2002 | 11:29 PM
Turbo95Max's Avatar
custom axles eh??? might have to inquire about those...i know Matt might want a set too!! heeh
anyways, from what i have heard, (not 100% sure) that most import connecting rods are shot peened already. on my pistons, we put this black coating on the piston skirts, what its suppose to do is draw heat away from the piston dome and to the skirt area where the oil can remove the heat.
Old Mar 21, 2002 | 02:07 AM
Chinkzilla's Avatar
Since you seem to have JWT's ear tell them to make more parts for the maxima =P. Apparently they don't think there's much money in it!
Old Mar 21, 2002 | 02:39 AM
Nismo87SE's Avatar
You have pretty much covered the basics. The only other thing is to swap your old IM to a 2000+ VQ dual capacity IM, and headwork. Since you are reving the motor higher than normal I guess getting a more aggressive street port work. Also what type of cams are you going to use? VQ30DET stock cams should work alot better than USDM VQ30DE cams assuming they aren't the same. I was wondering wouldn't it have been easier to just use a JDM VQ30DET short block? Then you would be able to part out your old VQ.
Old Mar 21, 2002 | 07:37 AM
Ron, perhaps cryogenically treating the rods would be helpfull, ask JWT about this?
shilov
Feb 19, 2024 09:40 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
