Bump Stops
Old Mar 23, 2002 | 12:17 PM
mattattax's Avatar
Bump Stops
What are bump stops and do I need to have them cut before installing my H&Rs on my 2k2? I've seen this asked several times in my searching but no answers.
Old Mar 23, 2002 | 01:55 PM
OriginalMadMax's Avatar
Re: Bump Stops
Bump stops keep you from bottoming your suspension, which can either blow the struts or bind (flatten) the springs. What you want to avoid is metal to metal impact. They also make the suspension more progressive by firming the bottom of the range of motion. One way to tell how much you need is to put a plastic wire tie on the strut and see how far up it pushes, then put in a bump stop a bit longer than the gap.
Old Mar 23, 2002 | 04:22 PM
Nismo's Avatar
they are attached to the dust boots. I cut my bumpstops in half
Old Mar 23, 2002 | 05:24 PM
mattattax's Avatar
thx
Old Mar 23, 2002 | 06:10 PM
theMax's Avatar
do you have a gxe?
For the SE the bumpstops are inside the dust boot and are made of foam. For the GXE they are part of the dustboots.
Old Mar 23, 2002 | 06:15 PM
Nismo's Avatar
Originally posted by theMax
do you have a gxe?
I have a GXE. I worked with the SE ones too and they are a "orange-ish" color foam that are inside the boot.
Old Mar 23, 2002 | 09:13 PM
mikese's Avatar
What happens if you don't cut it?
Old Mar 23, 2002 | 10:15 PM
Gotrice4's Avatar
you'll just be on your bumpstops more, b/c you have you have less suspension travel because of lowering springs...
Old Mar 23, 2002 | 10:43 PM
xHypex's Avatar
I don't know what shocks you are putting in, but when I put on my AGXs I put on KYB dust boots which had dustboots with the correct size bumpstops. Just another option.
-hype
Old Mar 24, 2002 | 06:40 AM
mattattax's Avatar
I'm just putting H&Rs on with stock shocks. Does anyone know when those adjustable Tokies (sp?) come out?
Thanks for the help
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
maxima297
Sep 30, 2015 03:32 PM
homewrecker
Sep 24, 2015 07:01 PM
