Installed 2k Muffler this weekend
Old Nov 26, 2000 | 03:26 PM
Confused's Avatar
Permanent Maxima.org Resident
Not a bad fit, had to adjust it forward a little bit under the car because the b-pipe was rubbing against the gas tank.
This was because my courtesy b with extension was not a good fit and had nothing to do with the muffler.
It has a little different tone but as expected, no noticeable gains.
Old Nov 26, 2000 | 03:31 PM
Wizeguy's Avatar
With it positioned where it is the exhaust gas will melt your rear bumper cover and discolor it. It needs to be out further.
Old Nov 26, 2000 | 03:34 PM
Confused's Avatar
Yeh, I noticed that.... will look around for a different
tip to release the gas away from the car.
Old Nov 26, 2000 | 03:38 PM
Wizeguy's Avatar
It's almost to bad you couldn't fine a 2 into 1 outlet. That way you could use the stock round location.
Old Nov 26, 2000 | 03:44 PM
Vic's Avatar
Vic
Looks good...don't worry about the position of the muffler under bumper that much. Lots of cars even 4th gen max's without the chrome tip sits underneath your bumper. If you have a white car..that would be a different story =)
still wondering why there are so many crickets underneath my hood...sheesh..
Vic
Old Nov 26, 2000 | 03:53 PM
Wizeguy's Avatar
I put an aftermarket muffler on my last car. It caused the polyurethane get hot and wrinkle up. It was postioned at about the same spot. That's been my experience.
Old Nov 26, 2000 | 04:19 PM
ZuMBLe's Avatar
Doh, no gains? How disappointing. How did you get the muffler? Bought it new? Used? If bought. How much?
ZuM
Old Nov 26, 2000 | 04:20 PM
theblue's Avatar
I like... but I would either fiberglass off where the old pipe came out (cause you're not using it), or cut it bigger to match the exhaust.
Old Nov 26, 2000 | 04:25 PM
Confused's Avatar
Bought used from someone here, had the pipe
chopped off of it so $100 took the prize.
I look at mods like computers.... you can't see a 5% faster computer with the human senses.... you need benchmark testing which I didn't do. How can you add a few hp and proclaim it noticeable.... Maybe some guys can but my boney butt can't.
ZuM
Old Nov 27, 2000 | 02:29 AM
Chunger's Avatar
My other car is a Hybrid
Looks great...
I'm tempted to get one to get rid of the 'noise' problem myself...
It's kinda hard to give up a nice and shiney muffler with big tip...lol
I did put in some of that "insulator" stuff from JEGS... that padding with foil lining... I lined my trunk and the rear seat with it... I haven't had time to drive it and see if it makes a difference yet...
Old Nov 27, 2000 | 06:23 AM
AntGVR4's Avatar
Looks good
It looks good...
I've been wanting one for a while....it's definately a better choice then any aftermarket muffler..
Thanx for the pics..
Ant
Old Nov 27, 2000 | 06:31 AM
Synki's Avatar
Re: Looks good
Originally posted by Ant95se
It looks good...
Ant
Your gunna need more then that buddy.
Old Nov 27, 2000 | 07:44 AM
SE-Raider's Avatar
Muffler Tip Mods
I installed a Y2K on my 98 SE. I traced the existing cutout on the bumper cover to use as a template, looking straight at the bumper from the rear. I then cut the template vertically in half at the highest point of the arc. I measured the distance between the centers of the tips, and added the length between centers as a straight line between the two halves, to allow about 1" clearance between tip and bumper, as per factory system. I traced the resulting template to the bumper cover using a grease pencil, and cut the line with a coping or keyhole saw (very easy to cut). I then lined the edge with self adhesive door edge moulding, black, to match the SE's trim. Looks factory. I also adjusted the tip length to extend 1/2" beyond the bumper cover by using the set screw on the tip assembly. I have had no problems with heat or discoloration, despite several late summer traffic jams with extended idling. Hope this helps.
Old Nov 27, 2000 | 07:47 AM
theblue's Avatar
Re: Muffler Tip Mods
Do you have any pics to share?
Old Nov 27, 2000 | 08:00 AM
SE-Raider's Avatar
Re: Re: Muffler Tip Mods
[QUOTE]Originally posted by theblue
[I]Do you have any pics to share?
sorry, no digital camera or scanner.
Old Nov 27, 2000 | 04:03 PM
Confused's Avatar
Re: Re: Bought used from someone here, had the pipe
You ARE my benchmark Doug... remember
Confused 2
Doug 0
Originally posted by doug
some of us see gains at the track
ZuM
Old Nov 27, 2000 | 04:29 PM
Confused's Avatar
I'm going to improve my r/t & 60 foots
either that or get a s/c :
I like that.. but you know... your almost maxed out on mods and I am only getting started... now if we are this close and i have only started... what is going to happen when we are even in mods?
Old Nov 27, 2000 | 05:46 PM
Confused's Avatar
just going to stay n/a and duke it out
it's more fun that way. now get rid of that hidious putty already.... it was funny the first 100 posts.
you can't keep running brett... you get an S/C i am right behind you.. then what you going to do?
Old Nov 27, 2000 | 06:03 PM
Confused's Avatar
LOL! love the new sig
I sure hope I stay up in the North East so we can continue this rivalry next season.. we all know Ant is no competition.. if I stay up here.. i am going to mod during the winter...
Old Nov 27, 2000 | 08:43 PM
Lordrandall's Avatar
I30Krab did a dual to single conversion. I don't know if he has any pics tho'.
Old Nov 27, 2000 | 09:06 PM
Confused's Avatar
thank you lord
randall.... i'll have to ask him when i see him.
Old Nov 28, 2000 | 06:40 AM
JJW95SC's Avatar
Re: Looks great...
Yea, I'm thinking that quieter would be better....I must be getting old.
Jim
Old Nov 28, 2000 | 08:43 AM
AntGVR4's Avatar
Re: Re: just going to stay n/a and duke it out
[QUOTE]Originally posted by doug
[I]I .. we all know Ant is no competition..[QUOTE]
Doug---> <---- Ant
Muhahahahahahahaha
Don't mess with me doug..
I'll come down to Texas next summer if i have to
Ant
MaxLife17
Jun 27, 2019 01:37 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Vequity
Sep 10, 2015 05:26 AM
MaxLife17
Sep 8, 2015 02:36 PM
TheMafia
Sep 4, 2015 08:26 AM
