I have more boost!!!!!
Old Apr 22, 2002 | 10:02 PM
The New CLIMAX's Avatar
No longer can I be called Mr. 2 PSI
I owe all thanks to Matt aka Mardigrassmax, he gave me advise on what to do and helped me correct the issue. Not only do I have boost but I also have more FP (fuel pressure.) I was able to hit 7PSI of BOOST with about 77-80PSI of FP. Now its time to get more boost, just call me Keving
Thanks again Mardi, now I just have to figure out the P0105 Manifold Absolute pressure/barometric pressure circuit malfunction (MAP sensor). It came on during my boosting runs last night.
Old Apr 22, 2002 | 10:25 PM
Maxtor
So is it fast now?
Old Apr 22, 2002 | 10:33 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Don't hook up a vacuum line from your manifold you retard. If the vacuum line is above vacuum, the ECU will throw a code.
That vacuum line needs constant vacuum...
Old Apr 23, 2002 | 07:17 AM
MardiGrasMax's Avatar
A binder clip thats worth 5psi!!! What a deal!!!
Maybe you can put a vacume check valve just before the MAP sensor?
Old Apr 23, 2002 | 07:55 AM
Y2KevSE's Avatar
He probably has other lines hooked up incorrectly (i.e. variable intake switch).
Dyno time!
Old Apr 23, 2002 | 10:10 AM
sleepermax's Avatar
Re: I have more boost!!!!!
Maybe now you could beat my old (slow) auto!
Old Apr 23, 2002 | 03:13 PM
JAY25's Avatar
this is the same code I get when I go to the track 0105 what did you do to fix this problem?
Old Apr 23, 2002 | 03:30 PM
Y2KevSE's Avatar
On the 5th gens (not sure if it's the same on 4th gens), if you hook up the MAP sensor to a vacuum line from your manifold, it'll throw a code when you boost.
Old Apr 23, 2002 | 05:47 PM
AHHHH now I need to correct the vacuum lines and I am lost, who can help, I need to see on a 5th gen. Thanks
Old Apr 23, 2002 | 05:48 PM
Dyno time!
So would I be getting more power now, I mean last time I dyno'd and it was ~250 FWHP with 2PSI, should it change?
Old Apr 23, 2002 | 06:45 PM
gtr_rider's Avatar
192.168.1.1
Are you serious?
Old Apr 23, 2002 | 08:07 PM
JAY25's Avatar
Thank you for answering my question Ill check that to see if thats the problem but it will only do it only when I hit 10PSI. . I dont recall hooking up the MAP, to a vacuum line though. Ill check it tomorrow or Thursday this will be the final test since I wont be going to the track for a while, not unless Mardigrasmax invites me one final time.
Old Apr 23, 2002 | 09:46 PM
Y2KevSE's Avatar
Don't look at any of my old pics because I've moved lines around. If you want, I can take a few shots tomorrow.
250 FWHP sounds about right since My 4DSC dynoed at about 246 (6.5 psi).
You're welcome.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
hozay99
Sep 19, 2015 10:20 PM
