Changing tranny oil, Have some questions
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I getting ready to change my tranny oil to redline and I have some questions. Do I have to buy a flush kit to get the old tranny oil out? Can I mix the redline with the old tranny oil if I didn't do a flush? Also how often should I be changeing the tranny oil?
Thanks.
Thanks.
i don't think you really need to flush it. just locate the fill plug first, remove it, then locate the drain plug, drain the old fluid out, and put the redline in. you might need some sort of funnel attached to a garden hose to make the filling process easier.
i think maximas don't require changing manual tranny oil at all. it won't hurt though, especially if you're using redline, you'll have smoother shifts
Originally posted by Nismo
So mixing synthetic with factory gear lube will not cause any weird reactions?
Originally posted by iwannabmw
There won't be any issues with mixing synthetic and conventional fluids. Changing your tranny fluid is as easy as changing your engine oil.
Originally posted by ATLMax
Anyone got a picture of where the fill plug is? I can't find it on my 96 SE 5sp.
Go to the "How To" section!
MatthewsMaxima
09-11-2015 03:21 AM
RealityCheck
08-05-2015 06:18 AM
