Just changed the oil myself.. very easy
i've seen my brother changing the oil, but never wanted to bother with it. Today since the weather is so nice i decided to do it. Considering i had the big pan to drain the oil to and basic tools handy, it was unbelievably easy task. It also give a great feeling of satisfaction.
Peace
Peace
Re: Just changed the oil myself.. very easy
Peace
Peace
Congratulations
Now you can appreciate this golden oldie....
Oil Changing Instructions for Women:
Pull up to Jiffy Lube when the mileage reaches 3000, since the last oil change. Drink a cup of coffee. 15 minutes later, write a check and leave with a properly maintained vehicle.
Money spent: Oil change $20.00
Oil Changing Instructions for Men:
Go to O' Reillys Auto Parts. Write a check for $50.00 for oil, filter, kitty litter, hand cleaner and a scented tree.
Discover that the used oil container is full. Instead of taking it back to O'Reilly to recycle, dump in hole in back yard.
Open a beer and drink it.
Jack car up. Spend 30 minutes looking for jack stands.
Find jack stands under kid's pedal car.
In frustration, open another beer and drink it.
Place drain pan under engine.
Look for 9/16 box end wrench.
Give up and use crescent wrench.
Unscrew drain plug.
Drop drain plug in pan of hot oil: get hot oil on you in process.
Clean up mess.
Have another beer while watching oil drain.
Look for oil filter wrench.
Give up. Poke oil filter with screwdriver and twist off.
Another beer.
Buddy shows up. Finish case of beer with him. Finish oil change tomorrow.
Next day, drag pan full of old oil, out from underneath car.
Throw kitty litter on oil spilled during step 18.
Beer. No, drank it all yesterday.
Walk to 7-11. Buy beer.
Install new oil filter making sure to apply a thin coat of oil to gasket surface.
Dump first quart of fresh oil into engine.
Remember drain plug from step 11.
Hurry to find drain plug in drain pan.
Discover that the used oil is buried in a hole in the back yard, along with drain plug.
Drink beer.
Uncover hole and sift for drain plug.
Discover that first quart of fresh oil is now on the floor.
Drink beer.
Slip with wrench tightening drain plug and bang knuckles on frame.
Bang head on floor boards in reaction to step 31.
Begin cussing fit.
Throw wrench.
Cuss for additional 10 minutes because wrench hit Miss December (1992).
Beer.
Clean up hands and forehead and bandage, as required, to stop blood flow.
Beer.
Beer.
Dump in five fresh quarts of oil.
Beer.
Lower car from jack stands.
Accidentally crush one of the jack stands.
Move car back to apply more kitty litter to fresh oil spilled during step 23.
Beer.
Test drive car.
Get pulled over - arrested for DUI.
Car gets impounded.
Make bail. Get car from impound yard.
Money spent:
Parts 50.00
Beer 25.00
Replacement set of jack stands.
Hey, the colors have to match!!!! 75.00
Bail 1000.00
Impound and towing fee 200.00
Total: $1350.00
But you know it's done right!
Unscrew drain plug.
Clean up mess.
Another beer.
Drink beer.
Drink beer.
Begin cussing fit.
Throw wrench.
Beer.
Beer.
Beer.
Beer.
Beer.
Test drive car.
Car gets impounded.
Money spent:
Parts 50.00
Beer 25.00
Bail 1000.00
Total: $1350.00
Originally posted by SterlingMist00
How did you support your car when you crawled underneath it??
Hope you used secure jack stands or the equivelant!
i know youre sposed to use a solid jack for any under car work, but this is just removing a screw...
Peace
Peace
Originally posted by magnum
i just used the jack that came with the car.. is that bad to do?
Thnx
After jacking up the car I put some wooden blocks next to it under the car, just for security. I didn't come upon any complications. It was easy, quick, and with no problems. I also read the oil change section in the manual before i started.
Originally posted by SSandMaxima
You don't have to jack the car when you change the oil on a 5th gen Maxima that hasn't been lowered.
u know i never changed my oil before....
why do it yourself for 50 when u can have them do it for u for 20? do they change your oil filter?
for 20 they probably don't...in taht case, when are u supposed to change oil filter? every time u change oil? i have to change oil within next 300 miles so i may do it myself this time...good weather is here now anyway....
Re: Congratulations
Unscrew drain plug.
Clean up mess.
Another beer.
Drink beer.
Drink beer.
Begin cussing fit.
Throw wrench.
Beer.
Beer.
Beer.
Beer.
Beer.
Test drive car.
Car gets impounded.
Money spent:
Parts 50.00
Beer 25.00
Bail 1000.00
Total: $1350.00
Unscrew drain plug.
Clean up mess.
Another beer.
Drink beer.
Drink beer.
Begin cussing fit.
Throw wrench.
Beer.
Beer.
Beer.
Beer.
Beer.
Test drive car.
Car gets impounded.
Money spent:
Parts 50.00
Beer 25.00
Bail 1000.00
Total: $1350.00
Re: Mastercard
5 qts of syntec blend oil - $12.50
1 oil filter - $3.50
Knowing you did it right, the satisfaction, and pride - priceless.
my oil filter costs over $10 which makes me not want to change
my oil...but i use mobil 1 oil filter
besides i dont like hving ppl i dont know touching my car
Re: Congratulations
Unscrew drain plug.
Clean up mess.
Another beer.
Drink beer.
Drink beer.
Begin cussing fit.
Throw wrench.
Beer.
Beer.
Beer.
Beer.
Beer.
Test drive car.
Car gets impounded.
Money spent:
Parts 50.00
Beer 25.00
Bail 1000.00
Total: $1350.00
Unscrew drain plug.
Clean up mess.
Another beer.
Drink beer.
Drink beer.
Begin cussing fit.
Throw wrench.
Beer.
Beer.
Beer.
Beer.
Beer.
Test drive car.
Car gets impounded.
Money spent:
Parts 50.00
Beer 25.00
Bail 1000.00
Total: $1350.00
When I change my oil, I jack up the front of the car, put it on jackstands, then turn the wheel all the way to the right. The plastic splashshield is easy to remove (make sure you have a stubby philips screwdriver handy), and the filter and drain plug is right there. There are several 10mm bolts for the splashshield, and the oil drain plug is 14mm.
The cost for me is around $3.75/qt for Mobil One 5w30 from Costco, and my dealer sells Nissan filters for $5.00 each. So, overall it costs around $25.00 in parts for oil change. The total time required is around one hour, including cleanup and pouring all the old oil into plastic containers. And don't forget the time needed to drive your oil to a recycling center (such as Kragen (I know some places collect it by the curb).
Now, you can get the same service at Jiffy Lube (they use Pennzoil synthetic I think) for around $50.00
It all depends whether changing your own oil is worth your time. For me, it is.
If you need to jack the car up and work under the car, please please get some jack stands. The jack that came with the car is only just enough to lift the car so you can change your flat tire. In a tire changing procedure, if that jack does somehow tip over, at least you would not be under the car.
DW
DW
I've done it before
but I still pay to get it done..
20$ at that 10 min. oil change place about 3 blocks after New Dorp lane, on the left side if going towards the Verazanno and they give a free car wash across the street.. since we have that water restriction thing in NYC that you can't wash your car, it is useful..
When we got our first oil change 2 weekends ago (1800 miles), I asked the Nissan Service guy to show me how to do it. I get it for the most part, but changing the filter seems kinda hard. We only went to the dealer to get the oil change because it was free and my dad really wanted to use it...lol But from now on, we are going to buy some Mobil 1 SuperSyn from costco and bring it to a shop to change it for like 10 bucks. I want to learn how to change my own oil not just to save 10 bucks..but to finally become a man.
Definitely invest in some jack stands! I got two 2.25 ton jack stands and a floor jack, all Craftsman brand, at Sears for $25 on sale. Money well spent. Not only is it safer than using the scissors jack that came with the car, it's also much easier to use.
You don't really need to jack your car up to change your oil anyway. Just turn the wheel all the way to the right and take the panel off. On my 4th gen it's just held on by two 10mm bolts and two plastic clips.
This has more response to it than I thouhgt it would. This is like the easiest thing know to man to do. I can change the oil rotate the tires and put brakes on my car in an 1hr. 1hr and 30mins at the most. And not a mechanic either. Just don't believe in letting other people work on my car. I changed my automatic transmission fliud and filter the other day. Nissan has the greatest invention since sliced bread on the trans. pan an actual drain plug for the trans. This was a farley simple task also took me about an 1hr.
doctorpullit
07-20-2019 09:31 PM
kjlouis
10-03-2015 05:29 AM
97_GXE
20
09-17-2015 08:12 PM
ag90fox
09-09-2015 12:22 PM
sdotcarter
09-02-2015 09:53 PM
