what is the purpose of...
Old May 13, 2002 | 05:35 PM
Cumalittle
a pilot bushing for the clutch assembly?
is it important?
Old May 13, 2002 | 08:14 PM
Cumalittle
over 40 peep read this...but no answer...wassup with that yo?
Old May 13, 2002 | 11:57 PM
krzymax's Avatar
Maxima owner since 2000
are you related to cumalot?
Old May 14, 2002 | 05:00 AM
Cumalittle
possible....now back to my question...anyone???i knoe some one on here must knoe...
Old May 14, 2002 | 05:41 AM
njmaxseltd's Avatar
Th pilot bearing is what the clutch master slave piston shaft pushes against to disengauge the pressure plate from the flywheel.
The Clutch Slave Cylinder Piston Shaft doesn't spin, your pressure plate does, thus you need a bearing to push up against. When the bearing goes bad, it squeals when you depress your clutch.
Another name for this is a throw out bearings.
Old May 14, 2002 | 06:19 AM
sighere's Avatar
The pilot bushing is not the throwout bearing. The throwout is what pushes the clutch in and out as you engage and disengage. The pilot bushing is at the end of the tranny shaft. It sticks into the flyweel hole and keeps the shaft centered. I can only assume that if you didn't have it, your shaft would flop around and wear out your tranny's bushings/seals/bearings.
Old May 14, 2002 | 06:25 AM
1BADMAX's Avatar
You told him.
Old May 14, 2002 | 03:47 PM
Cumalittle
now we're goin somewhere...but the shaft on the tranny does not look like the clutch alignment tool...only thing that is the same is the teeth...the clutch alignment tool slide rite into the pilot bushing but the tranny's shaft only has teeth no smooth part like the alignment tool...
Old May 14, 2002 | 03:58 PM
Jeff92se's Avatar
I'm needing a caw
This thread is rated R
Rice
Ridiculas
Racy
Really odd information
Your choice.
Old May 14, 2002 | 04:24 PM
Cumalittle
Rice
Ridiculas
Racy
Your choice.
um did u reply to the rite thread??? i'm confused...
Old May 14, 2002 | 04:32 PM
Jeff92se's Avatar
I'm needing a caw
Yes, by the replies I understand
i'm confused...
Old May 14, 2002 | 04:48 PM
Cumalittle
wtf??? i asked a question regarding pilot bushing...if u didn't want to answer it then so be it...i feel u are trying to poke fun or something...not coo at all...
erictown
Aug 20, 2015 08:01 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
Brandon90gxe
Nov 26, 2000 08:41 PM
