Gum on Carpets.....
Old Jun 25, 2002 | 03:25 PM
Nore474's Avatar
Gum on Carpets.....
Today I was cleaning out my car and I noticed that there was a wad of gum on the carpet i picked at it but how can I get that stuff out?
Old Jun 25, 2002 | 03:52 PM
sbslacker's Avatar
Re: Gum on Carpets.....
Freeze it with an ice cube (or two). Your carpet will get a tad wet, but the gum will turn solid and you can pry it right off.....
Old Jun 25, 2002 | 04:04 PM
95emeraldgxe's Avatar
WD 40 works, but it might require you to shampoo the rug
Old Jun 25, 2002 | 06:01 PM
mb1's Avatar
mb1
Use regular vinegar and a rag, and rub it out. It worked for my seat.
Old Jun 25, 2002 | 06:52 PM
ms.thicknes's Avatar
I found this stuff at kmart to clean the same thing on my carpets at home
it comes in a red spray bottle
it's called "Pro Shop Garage, Driveway & Patio Cleaner" cleans grease, oil and grime
yes it supposed to be for the outside cement driveways...but MAN does it clean up gum realllllll good...just spray the spot rub it in and in about two minutes you can pick the gum off with a fingernail!!!
(back of the bottle says it is maximum strength, ready to use formula, fast and effective for driveways, garage floors, patios, sidewalks, floors, engines, tools , barbeque grills, garbage cans, lawn mowers and works quickly without hard scrubbing)
it's produced by the national interchem corp....
i'm gonna stop typin now all of that may have been TMI!!
Old Jun 25, 2002 | 07:52 PM
Nore474's Avatar
THANKS
ALRIGHT GUYS THANKS I'LL GIVE IT A TRY TOMMOROW
Old Jun 25, 2002 | 09:30 PM
lcf's Avatar
lcf
this is the BEST way and it works on any fabric! especially clothes and carpet! all you need is an IRON and a PAPERTOWEL. lay the napkin or paper towel over the gum and heat up the iron and commence ironing. it melts the gum and for some strange reason it attaches to the napkin to disappear from your carpet!
i assure you this is not a trick to make you smear melted gum even worse into your carpet!
just pull your car into your garage and grab the iron and papertowel.
BkMaxima2004
Detailing
Oct 10, 2005 05:52 PM
99NJMAX
Detailing
Aug 30, 2005 10:29 PM
kratz74
Detailing
Oct 3, 2003 11:14 PM
97MaxGurl
Oct 2, 2002 07:14 PM
mb1
Feb 25, 2002 04:52 PM
