Help, car has no power or response!
Old Jul 4, 2002 | 05:08 PM
brodaiga's Avatar
Long story made short, i have a SC 95 max. Been having starting problems, changed the battery and the problem wasn't solved, I then attempted to change teh 140A battery fuse and in the process, while disconnecting the battery terminals dropped the wrench somehow, and a spark of electricity ensued, now, I do not have any electrical response at all, how can I fix this? I hope this does not mean by ECU is fried? Thanks.
Old Jul 4, 2002 | 07:07 PM
nvmymax2's Avatar
Before you go freaking out about the ECU being fried, you need to check the battery itself and all of the fuses. More than likely you just blew a fuse or something. It is also possible that you could have drained a cell in the battery with the sudden surge from the metal connection that was made.
But if I were you I would check these things before worrying about the ECU, check that last.
Old Jul 4, 2002 | 07:31 PM
nismo2020's Avatar
Needs non-Maxima Friends
Re: Help, car has no power or response!
uh oh
sounds like a problem that 1MAX2NV had. id pm him and see of he can help. like blake said check every last fuse. if you can have the battery checked by a car parts store or switch out batteries with another car.
anymore details on the starting problem?
Old Jul 4, 2002 | 07:45 PM
Wizeguy's Avatar
My guess... Starter. Who has a 95-96 and hasn't replaced there's yet?
Old Jul 4, 2002 | 07:51 PM
Pervis Anathema's Avatar
I managed to put a battery in backwards once. (Don't ask ) It fried the alternator and melted a fusible link. Took me a while to figure out the link part. It is basically a piece of wire that melts at a certain voltage. It is designed to protect your electrical system and ECU. Check yours. Granted, my car is a VG. However, there has to be something similar for a VQ. Mine was attached to the positive terminal cable. It plugged in. Hope this helps and good luck.
Old Jul 4, 2002 | 08:22 PM
brodaiga's Avatar
Re: Re: Help, car has no power or response!
thanks for the advice guys, how do I check all the fuses? Some are obvious (little ones), but what about the larger ones or the relays?
Old Jul 5, 2002 | 05:22 PM
brodaiga's Avatar
EUREKA, problem fixed!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks for help
Old Jul 5, 2002 | 08:17 PM
iwannabmw's Avatar
So what was it?
Old Jul 7, 2002 | 09:15 AM
pocketrocket's Avatar
Originally posted by iwannabmw
So what was it?
Probably the fusible link. Blew when he shorted the battery terminals.
Old Jul 7, 2002 | 09:57 AM
brodaiga's Avatar
you're right rpocketrocket, but alternator is bad, have to get it fixed.
Lakersallday24
Jun 16, 2019 01:35 AM
JRod28
Feb 4, 2016 11:07 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
yat70458
Aug 3, 2015 01:16 PM
