Interested in another Hella Supertone deal?
Old Feb 21, 2003 | 11:51 AM
  #81
Sean97SE's Avatar
Mike something came up, next time I can pay is next friday. You can give my horn to someone else that is interested, I'd rather not make you wait. PM me.
Old Feb 21, 2003 | 11:37 PM
  #82
xsp00kyx's Avatar
Originally posted by MAXIN
Here
More info here
BTW, SoundMike is an excellent seller to purchase from, keeps his buyers in informed throughout the sale.
Thanks again Mike.
sound clip is messed up. no audio...
Old Feb 22, 2003 | 07:33 AM
  #83
soundmike's Avatar
Very sound, Mike
xsp00kyx, i have a video clip i took of Tanman's car but that got lost in my drive crash I'll see if i can find someone else in Houston that has the Supertones installed and record that.
I have to warn you though, video/audio recordings doesn't do it justice. When i recorded Tan's installation it definitely was not as loud as when i heard it in person. May have something to do with the frequency range on the mic's of Video camera's.
MAXIN, Thanks for the kind words and the links
Sean97SE, No pressure or anything, but I can wait if you want me to. There's no rush, i already got both batches of Hella's come in and got a couple extra's. Just let me know
To those who e-mailed/PM'd me, I just got my other machine working so expect my responses to your questions sometime today. Got a *huge* backlog of e-mails to respond to.
Old Feb 22, 2003 | 09:59 AM
  #84
MAXIN's Avatar
works for me maybe you should try 'save as.' I did have to click it twice to make it work though.
Old Feb 22, 2003 | 10:58 AM
  #85
][ 35's Avatar
yup works just fine.... but like soundmike said i hope it's better then what on the recording in person...
Old Feb 22, 2003 | 11:07 AM
  #86
xsp00kyx's Avatar
yup got it to work with "save as" thanks
Old Feb 22, 2003 | 11:10 AM
  #87
xsp00kyx's Avatar
how's the installation guys? do you replace them with the stock horns?
Old Feb 23, 2003 | 04:04 PM
  #88
xsp00kyx's Avatar
Re: Re: Re: Satisfied Hella Supertone Owner
Originally posted by 97MaxGurl
yup- OE horn is out. The relay is included in the Supertone, run the relay as you would directly replacing the factory horn.
AnGe
can i see some pics ange? is it supposed to be installed right behind the grill? because i see pics of the 5th gen so i'm wondering if the 4th gen is the same? and the stock horns are near the drivers side right? never really paid attention to them. just making sure.=)
Old Feb 25, 2003 | 01:36 PM
  #89
hacim105's Avatar
Re: Re: Re: Re: Satisfied Hella Supertone Owner
on the 4th gen one horn is right in front next to the hood clamp or whatever it's called. The other is on the passenger side facing the engine.
Old Feb 26, 2003 | 07:08 AM
  #90
hacim105's Avatar
could someone post or send me the diagram they give you with the horn. I have lost mine and I don't know which wire goes to which slot. thanks. Or just tell me like the ground wire goes to number 30 slot, the signal goes to 98, etc.
Old Feb 26, 2003 | 07:24 AM
  #91
soundmike's Avatar
Very sound, Mike
Ok. Lemme see if i get this right:
Disconnect the earth lead of the battery while wiring the horns!
Wiring Diagram 1 - Switching option
Horn push negatively connected to existing horn
Battery + to 30 in relay. Hella's to 87. 85 to + line on existing horn. 86 to switch. Switch to horn and steering wheel.
Horn push positively connected to existing horn
Similar to above, except you loop back 85 to the relay.
Wiring Diagram 2 - Replacement option
Battery + to 30 in relay. Hella's to 87. Remove existing horn and connect 85 to the + of that line where the old horn was. 86 to steering wheel.
Horn positively connected to existing horn
That's my understanding of the diagram. Hopefully others will chime in and correct my info.
Old Feb 26, 2003 | 09:51 AM
  #92
hacim105's Avatar
Doesn't it say one of the wires from the relay is ground? If 86 goes to steering wheel then I'm guessing then that the line from the relay to the steering wheel would actually be connecting to the original connectors and 85 would be ground.
Old Feb 26, 2003 | 01:36 PM
  #93
MaximaMan77's Avatar
NO NO NO don't do that you'll fry fuses or the relay. There is no ground in the relay. All the relay does is route power to where it's need nothing less nothing more, just like a light swich in your house. You see your alarm and keyfob can sound the horn too thats why there are relays.
The gold connector on the horn is negitive/ground. With wire and some connectors from RadioShack attach that lead to the bracket to ground it then run the silver tab (positive) to the 87 of the relay. And 85 gets routed back to the relay.
Old Feb 26, 2003 | 03:46 PM
  #94
][ 35's Avatar
all this wiring this are giving me a headache.... i don't know anything about wiring and trying to learn.... where would be a good site to learn the basic of wiring......i'm still trying to install the horn i'm also trying to wire my radar to wires in my map light or visor light but having no luck so far... i suck at wires...
Old Feb 26, 2003 | 03:54 PM
  #95
hacim105's Avatar
I'm confused to.
If 86 connects to steering wheel, where does the steering wheel wire come out to connect to? How do I connect a wire to it when I don't even know where it is?
From what I understand of the write ups i've read.
30 goes to battery
87 goes to ground
85 goes to old signal connectors
86 goes to hella's
am I correct?
Old Feb 27, 2003 | 06:25 AM
  #96
I'm confused to.
30 goes to battery
87 goes to ground
86 goes to hella's
am I correct?
Sorry I was wrong. But I still don't understand why you would ground a relay.
According to what Polo has said this is how it's done.
Horn positively connected to existing horn <--this is the one we do.
30 goes to battery or other constant.
85 goes to steering ie. old power leads for horns. I would think you would jump them together into 85.
86 goes to ground.
87 goes to horn (silver lead) split the wire from 87 and run one wire to each horn.
Then run the gold lead on horn to the horn bracket to ground it.
If you have any more questions ask Polo he seems to know what he's doing.
I just swapped the horns and left the stock wiring with out the new relay and I don't have any problems. Their plenty loud but I may tinker with it again sometime.
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
