D2 Racing Coilovers. $700 SHIPPED. do NOT miss out !
Old Nov 10, 2004 | 05:46 AM
  #81
geo1317's Avatar
Originally Posted by southeast_first
5k (280 lb)
6k (336 lb)
7k (392 lb)
8k (448 lb)
9k (504 lb)
10k (559) lb
(taken from the first gd)
these are the most common spring rates for these coilovers. the higher the spring rate, the stiffer the ride. stock se springs are apparently close to 7k front/5k rear. on http://maxmods.dyndns.org, there is a section on springs which gives you some spring rates for comparison.
i might be in on this, is there a definite end date?
http://forums.maxima.org/showpost.ph...0&postcount=62
Are all these other rates available as well? Im really interested in the 3.5k
Old Nov 10, 2004 | 09:32 AM
  #82
VIP Maxima
can someone educate me and others on what spring rates are.
Old Nov 10, 2004 | 09:41 AM
  #83
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
i thought that when you have coilovers, the spring stiffness is adjustable, so why do we have to choose one before we buy them?
Old Nov 10, 2004 | 12:43 PM
  #84
1FSTMAX's Avatar
If this deal goes to next month then ill be in for a set for a a32.
Old Nov 10, 2004 | 01:54 PM
  #85
Keyser Skoze's Avatar
When should the money be sent? (from not until...?) because the car was broken into last night. If i had a week and a half i would be able to do it no problem.
Old Nov 10, 2004 | 02:36 PM
  #86
Bluesbrekr's Avatar
Doctorate in Detailing
I just emailed Mark240 from advautoparts (the seller) asking if he could post some info about how to choose spring rates.
Old Nov 10, 2004 | 02:41 PM
  #87
Triple8Sol's Avatar
I miss the .org!
Good call. This thing is moving along alot quicker than I expected! 700x20=$14,000 wow...
Old Nov 10, 2004 | 03:05 PM
  #88
brianw's Avatar
Coilovers usually have adjustable ride height, camber/caster if camber plates are included, and often adjustable damping as well.
Springs are a fixed rate at whatever you select. It is "selectable" in that most coilovers fit one of several universal spring diameters and lengths, often 2.5" diameter and between 7" and 10" in length. Instead of $150 for Maxima-specific springs you can spend $60-100 a set on the springs you want that will fit any coilover that accepts the same diameter spring.
Old Nov 10, 2004 | 06:06 PM
  #89
any word on when the funds should be sent?? ...between now and...??
Old Nov 10, 2004 | 07:04 PM
  #90
juani's Avatar
Rockin' VK56!!
Can you put me off the list.
Something came up, so i won't be able to join this GD.
If this deal last long enough, I maybe able to join.
Old Nov 10, 2004 | 08:59 PM
  #91
MAXimumHP's Avatar
Well, you can add me for a pair of A32's.
Has anyone had these and done a writeup on them other than kpazzo?
Old Nov 10, 2004 | 09:26 PM
  #92
Jupps's Avatar
me too!
Coolness! I am in for an A33 set. Thanx for the nice deal.
Old Nov 10, 2004 | 10:50 PM
  #93
NiZMo1o1's Avatar
how long will these GD last or the end date for purchase ? just got a y2k max and been researching between suspensions.
cattman has a nice AGX setup but I would rather go with a fully coilover kit.
Is there any updates with the previous complaints about the rubber being torn that cause the clunking noise?
Is there anymore feedbacks?
I know this is a Great Deal esp on coilovers but I want to be assured with a quailty ride without the Noises.
Old Nov 10, 2004 | 10:59 PM
  #94
VIP Maxima
1) 98MikeXimaSE..............A32
2) 03BlkSETE...................A33
3) Dohcser......................A33
5) Iilac...........................A32
6) Bluesbrekr...................A33
7) Triple8Sol....................A33
8) MAXimumHP.................A32
9) nismo star ..................A33
10) nadeemp8..................A33
11) cardana24.................A32
12) slimer........................A32
13) Keyser Skoze..............A32
14) kaptainkrunk...............A32
15) frankieduxAE................A33
16) MikeD95SE...................A33
17) Max97Stick...................A32
18) Jupps..........................A32
Old Nov 10, 2004 | 11:00 PM
  #95
VIP Maxima
im not able to answer any of these questions, i leave it up to mark, i think he is on a vacation or something cuz he isnt answering emails. remeber guys, im a regular org member like U and im not in charge of this deal... lol
Old Nov 11, 2004 | 01:09 AM
  #96
Lonely Driver's Avatar
2 sets for A32.
Old Nov 11, 2004 | 03:48 AM
  #97
Bluesbrekr's Avatar
I got an email back from Mark.....
Thanks for the email! The computer here got infected with impossible to remove spyware yesterday so I haven't yet read the forum post. I will get to it within the next couple hours!
Mark
Hopefully he'll be posting soon with some info.
Old Nov 11, 2004 | 04:09 AM
  #98
Jupps's Avatar
I have a 2k2, so I suppose I should get a set for A33. Thanx in adv. for fixing this.
Old Nov 11, 2004 | 10:42 AM
  #99
VIP Maxima
18) Jupps..........................A33
19) Lonely Driver.................A32
20) Lonely Driver..................A32 (2nd set)
Old Nov 11, 2004 | 10:44 AM
  #100
mark240's Avatar
Mark
The computer is now all formatted and fresh. I just have to restore all the old files back onto the hard drive so I will post a spring rate chart and recommended spring rates for each purpose within about an hour. Was this the only major question to answer?
Mark
Old Nov 11, 2004 | 11:13 AM
  #101
mark240's Avatar
Spring rate conversions:
0 Kg/mm 0 Lb/In
1 Kg/mm 56 Lb/In
2 Kg/mm 111.9 Lb/In
3 Kg/mm 167.9 Lb/In
4 Kg/mm 223.8 Lb/In
5 Kg/mm 279.8 Lb/In
6 Kg/mm 335.7 Lb/In
7 Kg/mm 391.7 Lb/In
8 Kg/mm 447.6 Lb/In
9 Kg/mm 503.6 Lb/In
10 Kg/mm 559.5 Lb/In
11 Kg/mm 615.4 Lb/In
12 Kg/mm 671.4 Lb/In
13 Kg/mm 727.4 Lb/In
14 Kg/mm 783.4 Lb/In
15 Kg/mm 839.2 Lb/In
16 Kg/mm 895.2 Lb/In
17 Kg/mm 951.2 Lb/In
18 Kg/mm 1007.1 Lb/In
19 Kg/mm 1063.2 Lb/In
20 Kg/mm 1119 Lb/In
21 Kg/mm 1175 Lb/In
22 Kg/mm 1230.8 Lb/In
The recommended spring reates are 8/6 for normal street handling and 10/8 for track / racing.
Old Nov 11, 2004 | 11:20 AM
  #102
VIP Maxima
mark, what are spring rates??
and are we going to adjust the rate to these numbers or the coilovers come with DIFFERENT settings that can be adjusted as well??
  #103
mark240's Avatar
Payment details
Payment details:
The quicker we get payments in, the quicker we can place the order. Payment can by made by PayPal, credit card, money order, check, or wire transfer.
PayPal = keys@zxdriver.com
Please leave a note with your chassis code or year of car and your preferred spring rates.
Credit Card = Call (416) 835-8490 anytime after 9:00am PST
Money Order or Check =
ADV
1051 Clinton Street
Buffalo, NY 14206
Wire transfer =
Email or call me if wire transfer details are required.
We will give a week or two leeway before sending in the spring rates to the manufacture so well they are devoloping the shocks, people may email us to change their spring rates if they wish.
Old Nov 11, 2004 | 11:23 AM
  #104
cardana24's Avatar
Blown
I can send money next friday...is that too late?
Old Nov 11, 2004 | 11:31 AM
  #105
Bluesbrekr's Avatar
mark240, thanks for the quick and thorough response about spring rates. Much appreciated!
Old Nov 11, 2004 | 11:32 AM
  #106
looslip's Avatar
Horra!!
Mark,
I would also like to know when is the latest we can send our payments. I really need to find out if these can be fit into my budget. Thanks.
Old Nov 11, 2004 | 11:47 AM
  #107
cardana24's Avatar
Blown
as long as we have 20 people can you just say you have to pay by mm/dd/yyyy? (ex. 12/1/04)? Is this an option?
Old Nov 11, 2004 | 12:00 PM
  #108
mark240's Avatar
Ok we will set the deadline for payment in 2 weeks by 11/25/2004. However, minimum selling prices of D2’s will be jumping any day now, we must have all sales locked in within a week with at least a $100 deposit by 11/18/2004. I hope that is understandable.
People can start sending full payments and deposits now. Please do not wait until the last minute though because the D2 minimum selling price is rising soon and we do not want the distributor to cut us off of future sales. What is sold and paid for is sold and paid for but coming very shortly (most likely within a week), we will not be allowed to sell these coilovers below a small % under MSRP
Old Nov 11, 2004 | 12:19 PM
  #109
cardana24's Avatar
Blown
do you mean 11's where you typed 12's (for the date)?
Originally Posted by mark240
Ok we will set the deadline for payment in 2 weeks by 12/25/2004. However, minimum selling prices of D2’s will be jumping any day now, we must have all sales locked in within a week with at least a $100 deposit by 12/18/2004. I hope that is understandable.
Old Nov 11, 2004 | 12:23 PM
  #110
limsandy's Avatar
Add me to the list for A33, 8k/6k F/R. I will be paying with my credit card, so I'll give you a call before 12/18/2004.
~limsandy
Old Nov 11, 2004 | 12:40 PM
  #111
03BlkSETE's Avatar
Just called,ordered, and paid.
Old Nov 11, 2004 | 12:57 PM
  #112
I put down $100 deposit now (I have 2 sets so $200). When you receive them from D2, then I pay for the balance. Am I correct on how the payment method works?
Old Nov 11, 2004 | 01:07 PM
  #113
mark240's Avatar
The $100 deposit will lock your name into the group buy so you are gauranteed a set at this price. It will help out people that need a couple weeks to come up with the money. All deposits must be received by 11/18/2004. Full payments must be received by 11/25/2004 so that we can pay for the coilovers. The deposits are enough to place the order with the manufacture on 11/18/2004.
Old Nov 11, 2004 | 01:10 PM
  #114
mark240's Avatar
2) 03BlkSETE...................A33 (Paid in Full)
19) Lonely Driver.................A32 ($100 Deposit)
20) Lonely Driver..................A32 (2nd set) ($100 Deposit)
Old Nov 11, 2004 | 02:46 PM
  #115
Vlasic's Avatar
i am in for a set of A32's. i will send at least a deposite of $100 by next week with my desired spring rates.
Old Nov 11, 2004 | 03:50 PM
  #116
VIP Maxima
im having a hard time understanding what spring rates are and what they do. i just want these coilovers for street use and best possible ride quality and i do plan on slammin down the car by at least 3 inches on 19" rims for street/highway use ONLY. i dont care about autox/drag racin or track racin or any of those lol. someone help me please !! what spring rate should i get that gives me about 3"-4" drop with best ride quality !
Old Nov 11, 2004 | 03:53 PM
  #117
Max97Stick
once we hit deal goes through right?
Old Nov 11, 2004 | 05:41 PM
  #118
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Mark
Is the rear mounts available for the A32? How much would it cost?
  #119
SLMD19Z's Avatar
You can count me in on this deal. I would like one for an A32 please. I'll call u for my payment info by next week. Thanx for the awesome deal.
Old Nov 11, 2004 | 09:42 PM
  #120
mark240's Avatar
Originally Posted by Iilac
Mark
Rear pillowball mounts are not made nor needed for the Maxima's. They however, include standard top mounts for the rear
