AMSOIL Synthetic Lubricants
Old May 3, 2016 | 07:37 PM
  #1121
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Originally Posted by cornholio
PM sent
Sent you cost and ordering info. Pls let me know what questions you have and if I can be of service
Thx
Old May 29, 2016 | 08:07 AM
  #1122
One-stop Shopping for your maintenance needs! Wholesale Pricing Available!
AMSOIL Synthetic Motor Oils: premium oils that run clean, reduce engine wear/horsepower loss and maximize efficiency. Oils for passenger cars, trucks, racing applications, motorcycles, diesels, RVs, off-road vehicles, snowmobiles, small engines and more.
AMSOIL Synthetic Automatic Transmission Fluid (including CVT): Improves shifting, and protects components for maximum efficiency, reliability and longevity. Formulations to meet/exceed Nissan-matic D, J, K and S performance specs. AMSOIL high performance synthetic CVT fluid available for vehicles with continuously variable transmissions.
AMSOIL Synthetic 75w-90 GL-4 Manual Trans and Transaxle Oil: meets hard-to-find GL-4 specs. Specially formulated for manual transmissions and transaxles that require a GL-4 lubricant
AMSOIL Synthetic GL-5 Gear Oil:Complete line of synthetic GL-5 gear oils for rear-drive vehicles
AMSOIL Synthetic Brake Fluid: Premium synthetic formulations for maximum braking system protection, long life and improved braking performance under the most extreme conditions. DOT 3 and DOT 4 Racing Brake Fluid formulations available
Filters from AMSOIL, Wix, Mann & Donaldson: Protect your engine with premium oil filters, air filters, cabin filters and fuel filters. Filters available for most applications
AMSOIL Fuel Additives: AMSOIL Performance Improver is the most potent fuel additive available on the market today. Cleans injectors and removes deposits from intake valves. Maximizes combustion efficiency for better fuel economy and performance. One bottle treats up to 20 gallons of fuel. Other additives available for small engines, motorcycles and diesel applications
AMSOIL Coolant: AMSOIL EG and environmentally friendly PG-based coolants are free of damaging Phosphates, Silicates and Borates. Unmatched protection for sensitive aluminum components
Detailed description of all products, an on-line application guide and a free on-line maintenance tracker can be viewed/accessed thru my website at http://lonestarlubes.myamsoil.com
23-yr Nissan owner, 14-yr org member, AMSOIL Certified Direct Jobber, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada. Pls send PM or e-mail direct at lonestarlubes@gmail.com for customized quote
Wholesale Pricing Available on All Products!
Old Jun 2, 2016 | 07:46 AM
  #1123
Benefits of AMSOIL Signature Series Motor Oil:
Protects Your Engine:
AMSOIL Signature Series Synthetic Motor Oil provides outstanding anti-wear protection. It develops a strong fluid film that keeps metal surfaces separated while its robust anti-wear additives further reduce wear in metal-to-metal contact regions for maximum engine life. In the industry-standard Sequence IIIG Engine Test, AMSOIL Signature Series Synthetic Motor Oil delivered 75 percent more engine protection against horsepower loss and wear than required by a leading industry standard.** For details, see the Double-Length Sequence IIIG Engine Test Technical Study http://www.amsoil.com/lit/g3320.pdf
Maximizes Fuel Economy:
Signature Series Synthetic Motor Oil is designed to maximize energy efficiency for optimum fuel economy. Unlike conventional oils, its uniform molecular structure helps it flow more freely and reduce friction between metal surfaces. Anti-friction additives are included to further improve energy efficiency.
Provides Reserve Protection over Extended Drain Intervals:
AMSOIL Signature Series Synthetic Motor Oil can extend drain intervals far beyond those recommended for conventional oils. Its unique synthetic formulation and long-drain additive system are inherently stable to resist oxidation and neutralize acids over longer periods. Signature Series is designed to deliver outstanding engine protection, cleanliness and performance over extended drain intervals. It reduces vehicle maintenance and waste oil.
Keeps Pistons Clean:
Excess piston deposits can lead to pre-ignition and engine knocking, which results in lost power, reduced fuel economy and, in severe cases, engine damage. Signature Series’ premium additives and naturally high resistance to extreme heat help keep pistons clean for maximum engine performance. Signature Series prevents piston deposits 93 percent better than required to meet the latest API standard.
Excels in Extreme Temperatures:
Signature Series resists thermal (heat) breakdown better than conventional and synthetic motor oils. It is heavily fortified with detergent and dispersant additives to help prevent sludge deposits and keep engines clean. Unlike conventional oils, Signature Series contains no wax, staying fluid in sub-zero temperatures for easier starting, improved oil flow and reduced wear.
Reduces Oil Consumption and Emissions:
Volatility (burn-off) occurs when oil gets hot, causing high oil consumption and emissions. Signature Series resists volatility better than other oils, helping reduce oil consumption and emissions.
Old Jun 13, 2016 | 02:25 PM
  #1124
Please send PM or e-mail direct at lonestarlubes@gmail.com for additional information and/or quote.
Wholesale pricing available on ALL products including premiere quality motor oils, transmission oils, gear lubes, additives, filters and more!
Using AMSOIL doesn't cost, it pays!
Old Jul 5, 2016 | 08:28 AM
  #1125
Old Jul 16, 2016 | 06:07 AM
  #1126
Old Jul 25, 2016 | 05:02 PM
  #1127
AMSOIL Synthetic Motor Oils: premium oils that run clean, reduce engine wear/horsepower loss and maximize efficiency. Oils for passenger cars, trucks, racing applications, motorcycles, diesels, RVs, off-road vehicles, snowmobiles, small engines and more. Independent lab tests show that AMSOIL Signature Series motor oil provides 75% greater protection against engine wear and horsepower loss than required by API SN requirements.
Old Aug 5, 2016 | 08:41 AM
  #1128
Old Aug 20, 2016 | 10:07 AM
  #1129
Old Sep 13, 2016 | 05:16 PM
  #1130
Old Sep 22, 2016 | 06:59 PM
  #1131
QT1 5MT AE's Avatar
Gram Lights addict
can u pm me a quote for 3 quarts of 75w90 gl4 shipped to 48122?
Old Sep 23, 2016 | 05:28 AM
  #1132
PM Sent...Pls let me know when you're ready to order
Thanks!
Old Oct 27, 2016 | 07:19 AM
  #1133
Check out the AMSOIL Informational video on Sequence IIIG test. Impressive!
Pls let me know if I can help. Pls send PM or email direct at lonestarlubes@gmail.com for pricing.
Wholesale pricing available on all products
Old Nov 10, 2016 | 08:19 AM
  #1134
Please send PM or e-mail direct at lonestarlubes@gmail.com for quote.
Wholesale pricing available! No pressure, no gimmicks!
Old Nov 23, 2016 | 07:45 AM
  #1135
Old Nov 30, 2016 | 06:46 AM
  #1136
Old Jan 8, 2017 | 10:55 AM
  #1137
For those of you who have modded their engines and/or who race, AMSOIL Z-Rod Motor oil with additional Zinc will provide additional protection to the flat tappets and other engine components that are under heavy stress.
AMSOIL Z-ROD Synthetic Motor Oil is specially engineered for classic and high-performance vehicles. It features a high-zinc formulation to prevent wear on flat-tappet camshafts and other critical engine components, along with a proprietary blend of rust and corrosion inhibitors for added protection during long-term storage. Z-ROD Synthetic Motor Oil is designed to perform on the street and protect during storage.
Z-ROD Synthetic Motor Oil meets API SL and earlier specifications, allowing for increased levels of anti-wear additives. ZDDP levels in Z-ROD Synthetic Motor Oil exceed the limits of API SM and newer specifications. Please see the Tech Data Sheet for additional information: http://www.amsoil.com/lit/databulletins/g2883.pdf
For fastest service pls e-mail direct at lonestarlubes@gmail.com with questions or for quote. Please include zip code or state to which we'll be shipping to aid in calculation of shipping cost and sales tax where applicable.
Wholesale pricing available on all products!
Here's also an AMSOIL Video on the topic:
Old Mar 8, 2017 | 06:42 AM
  #1138
Wholesale Pricing available on all AMSOIL products!
Pls e-mail direct at lonestarlubes@gmail.com with questions or for quote. No PMs
Pls include zip code or state to which we’ll be shipping to assist in calculating shipping and sales tax where applicable. Thanks!
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
pjgreek
Sep 9, 2015 09:30 PM
flu2000
22
Sep 2, 2015 07:29 AM
mclasser
Aug 23, 2015 09:32 PM
