100 watt Fog lights
Old Sep 16, 2004 | 10:26 AM
guysohigh's Avatar
SimStones
100 watt Fog lights
Can I use 100 watt H3 foglights, or do i have to use the 55 watt version? Will the 100's **** up my wiring, or burn something, or kill my fuse, or should i just stick with the 55 w super brights I say the other day.
Old Sep 16, 2004 | 10:27 AM
Dr.Monkey1313's Avatar
I tried this once and being the paranoid person I am, I took them out and put 55 watt back in because I was worried that the light housing was going to burn. When I had the 100 Watt in and touched the lense, it seemed really hot.
I would like to know this answer as well.
Old Sep 16, 2004 | 10:34 AM
Luigi38's Avatar
Hadlight bulb
Since we are talking about bulbs. Can you put 100W H4 in the cefiros?
Will it **** the housing? or should just stick with 55W Ultra Whites.
My cefiros came w/ 100 but one of them burned. They lit up the hole block
Old Sep 16, 2004 | 10:36 AM
leeI35's Avatar
G37S > I35 > UR Max
I think the more wattage bulbs you use 85-100, you will get a dis-color look inside the housing of the fogs or eventually burn themout if you use your fogs 24/7. I did that before on my acura (had the fogs rewired and ran them 10/7) and i completely burnout the housing. Had to buy 2 new fogs and that was costly. I am running silver stars in my I35 fogs and they are suppose to be 55watts however, something sylvania does to the bulbs, they are rated at 85 watts. I am a little paranoid of that, but I only put on my fogs when I want to show off or in a poorly lit area.
Old Sep 16, 2004 | 10:58 AM
guysohigh's Avatar
SimStones
well, my fogs are rewired yet, and I dont even run them everynight, but a friend of mine changed his fogs from 55 to 100, and the difference was super clear. I just dont wanna have to change the whole unit out if itz gonna mess up everything.
Old Sep 16, 2004 | 11:36 AM
Pizatt's Avatar
No to all questions asked above! I believe you have to upgrade the harnesses !
Old Sep 16, 2004 | 01:24 PM
I30tMikeD's Avatar
100w bulbs will heat up the plastic housing of the fog lights....and when you hit a puddle and it splashes on the fog lights the lens will crack. Happens to guys all the time.
Old Sep 16, 2004 | 08:35 PM
guysohigh's Avatar
SimStones
Thanks for the info, I guess i'll just have to find some bright 55 w fogs. Any suggestions other that silverstars?
Old Sep 16, 2004 | 09:56 PM
cefiro8701's Avatar
are u serious...i have 100 watt in mine and i havent seen any downsides yet...
Old Sep 17, 2004 | 05:00 AM
guysohigh's Avatar
SimStones
How long have u had them in?
Old Sep 17, 2004 | 07:00 AM
leeI35's Avatar
G37S > I35 > UR Max
PIAA H3 extreme whites come close to hid look.
Old Sep 17, 2004 | 08:01 AM
flthere's Avatar
what bulbs are the stock ones in fogs ?!? they look really bright and hot to touch after runnin them for a while. One thing, I am not sure if I have the stock ones coz I bought the car after it was driven for 96k.
Old Sep 17, 2004 | 08:55 AM
I30tMikeD's Avatar
Over the years I have heard of many guys cracking their fogs because of too high wattage of bulbs.
Old Sep 17, 2004 | 12:01 PM
leeI35's Avatar
G37S > I35 > UR Max
He also may not be driving his car or running his fogs all the time like i did. I had my fogs rewired and would drive with the park lights on all the time. Housing burnt completely out and it would have destroyed my engine harness. Luckily nothing electrical happened.
Old Sep 17, 2004 | 10:21 PM
cefiro8701's Avatar
guess what im eating my words...my fogs stopped tonite...hehehe....sucks for me...im totally F-cking up my first car...
Old Sep 17, 2004 | 10:28 PM
cefiro8701's Avatar
the housing burnt out??u meant that metal stuff the bulb connects to??i dunno
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
Maxima30
Sep 7, 2015 06:13 PM
