100watt lites
Old Oct 10, 2004 | 06:58 PM
cefiro8701's Avatar
100watt lites
i have 1 100 watt litebulb right now...does it have any risk of doing anything negative on the car?or should i be fine...i was running 100 watts on my fogs and they both died on the same day...any tips on fixing this ???should i keep my heads?
Old Oct 10, 2004 | 07:05 PM
azndude's Avatar
I think you should not risk it, I've had experiences with other cars when putting higher wattage bulbs in their original housings and using the original harnesses. Either the harness or the housing itself would slowly begin to melt (especially in the summer time but that doesn't mean that you should use them in winter time). The harness would emit a foul smell and the bulb would eventually fail as the melted plastic from the harness makes contact with the connection contacts of the bulb itself. Only maybe can you try upgrading to a better harness with a higher temperature resistance, and/or getting lower watt bulbs. Still, this does not prevent melting of the housing, so either way, your best bet would be to use weaker bulbs, sorry.
Old Oct 10, 2004 | 07:32 PM
cefiro8701's Avatar
so i should take off the 100's...what about silverstars?would they be safe?
Old Oct 11, 2004 | 11:05 PM
azndude's Avatar
the silverstars are fine, they should be using 'standard' or at least normal wattage suitable for the stock harnesses (don't quote me on this, but I'm pretty sure slyvania wouldn't like to pay for someone's melted headlights).
Old Oct 18, 2004 | 02:39 PM
SuBXeRo's Avatar
i know the post is a lil old but i have 100 watt bulbs in my stock housings, and i just had to upgrade the harness, the stock wiring shows sum Minor burning i mean like minor minor minor, but that could just be heat fromt he housing, the housing is fine and i havent had any problems, but i bought plasmaglow hyperwhites
Old Oct 18, 2004 | 03:15 PM
cefiro8701's Avatar
dude...ur seventeen too!!!what kinda mods u got?
Old Oct 18, 2004 | 04:49 PM
SuBXeRo's Avatar
led,s apline system, IM me on aim if u wanna talk more SuBZeRo69069
umnitza
Sep 1, 2015 01:03 PM
Nathan
Feb 20, 2002 08:38 PM
Y2KSilvahSE
Feb 12, 2002 12:04 PM
Nathan
Feb 4, 2002 02:49 PM
JacksMax
Dec 5, 2000 08:04 AM
