Clicking Noise When Turning At Low Speeds
Old Dec 29, 2004 | 08:58 PM
OZMADMAX's Avatar
Hey All,
My car has 160,000 kms (100,000 miles) and recently I have noticed a clicking noise when turning the steering wheel at low speeds, for example to park the car or make a U turn. It sounds a bit like when you run your hand along the wooden pales of a fence.
Has anyone experienced this? Any thoughts on possible causes?
Old Dec 30, 2004 | 08:17 AM
I30tMikeD's Avatar
Sounds like you have a bad strut bearing. Can't say for sure since this is an internet diagnosis. Could also be a wheel bearing, but I don't think so.
Old Dec 30, 2004 | 08:56 AM
Weasel's Avatar
Does it keep clicking while you're not still turning the wheel but holding it at the same angle? If so it could also be a CV joint.
Old Dec 30, 2004 | 08:57 AM
I30tMikeD's Avatar
Ahhh, forgot that...yhea, could be the CV joint
Old Dec 30, 2004 | 08:59 AM
Paradox Cefiro
ive had both my cv joints replaced about 5k ago and im getting this clicking noise as well. Strut bearing? Im also lowered on kyb agx's and an eibach prokit
Old Dec 30, 2004 | 09:03 AM
I30tMikeD's Avatar
The strut bearing allows the front strut/spring to rotate when turning. Goes right under the strut mount. It is just a small circular plastic piece with bearing inside. What happens most of the time is the grease inside dries up not allowing the strut assembly to turn smoothly and the spring gets binded up causing a poping noise. Not much to it but the whole strut/spring assembly has to be disassembled to replace it.
Old Dec 30, 2004 | 03:10 PM
Paradox Cefiro
is it worth it to replace?
Old Dec 30, 2004 | 03:15 PM
I30tMikeD's Avatar
If one indeed has a bad strut bearing it needs to be replaced. Sure the car will drive with it bad, but the car will run on 5 cylinders as well
Old Dec 30, 2004 | 03:18 PM
OZMADMAX's Avatar
Thanks for all the posts.
The noise does not continue if holding the steering wheel at the same angle.
I have Koni Yellow suspension, which as you all know, in the front is an insert. Perhaps it is a strut problem. In any case the noise is not severe.
How urgent a problem is this to fix and should i approach my suspension installers or the Stealer?
Maxima.KsA
May 15, 2020 04:14 PM
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
