Vibration in steering wheel when at red lights
Old Jan 12, 2005 | 04:20 PM
NOCturnalI30's Avatar
Hay i need some serious help. My 2000 i30's steering wheel will vibrate at every red light. its very anoying and im loosing my patients with it. when i open the hood it seems like it gets worse when the radiator fans turn on. i looked under that hood and it seems like the back 2 pullys a pretty rusted but that could just be me. and only those 2 look like thay shake a like (like a off balance wheel) im not sure if that is the culprate but i would like some more ideas. please help!!!!
Old Jan 12, 2005 | 07:20 PM
lawrencel715's Avatar
bad ignition coils?
Old Feb 3, 2005 | 08:13 AM
I30racerx's Avatar
Is your idle low when you're stopped?
Do you have an auto? Do you notice that your idle drops when you come to a complete stop and leave it in Drive?
That was happening to my 98 I30. The RPMs would drop to ~ 500 when I was at a light. I cleaned out my throttle body and that helped a bit. Adjusting the idle screw would probably help with that too.
Old Feb 3, 2005 | 09:48 AM
I30tMikeD's Avatar
Sounds like just a misfire problem to me. Is the Check engine light on?
Old Feb 3, 2005 | 11:28 AM
PAREDLINE's Avatar
Just your steering wheel shakes? Or the whole car shakes...
Old Feb 3, 2005 | 02:30 PM
SuBXeRo's Avatar
mine shakes a bit too, but just alil bit, its just the idle in my car i hope, but i get low rpms at a light too around 1000, but thats normal, get it checked out i think before the problem can get worse, something doesnt seem right, and your car is only a 2000
Old Feb 3, 2005 | 07:13 PM
cefiro8701's Avatar
happened to my sdads car....it was his mounts...
Old Feb 3, 2005 | 08:29 PM
MetaOrbit's Avatar
Got Projectors?
Mine does the same thing, but it's not so severe. It also seems to only occur once the fans turn on. I've mentioned this to the dealer on several occasions, but they're never able to reproduce it. I can't really blame them though. I have trouble reproducing it myself, as it doesn't ALWAYS do it.
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
Flores94
Aug 13, 2015 01:17 PM
