AirConditioning Condensate Drain
Do you know where on 2002 model there is a condensate drain from the AC unit? I was looking on my I35 for it as I thought it could be plugged in, but could not find the drain tube.
Please advise
Please advise
![](https://maxima.org/forums/images/smilies/support.gif)
the only advice I can give is to try and find it at the bottom of the box that has the evaporator core in it, usually under the hood near firewall, and follow it from there. I wish I could look for you but car's in the bodyshop AGAIN, if you need help finding the housing for the evaporator core follow the low side line that comes from the compressor and doesn't go to the condensor, it should be cold w/ac on and have a blue cap over the service port.
On all other cars that I had including Maxima, 94, the drainage was clearly there.
Forge277
06-13-2016 09:26 PM
foodmanry
09-24-2015 12:02 PM
markevans999
09-10-2015 04:29 PM
