Rough drive after coil / plugs replacement
Old Dec 27, 2006 | 11:43 AM
mohiudr's Avatar
Hi all,
I changed all 6 ignition coils and spark plugs for my 2000 I30t. Purchased the parts from http://www.infinitipartsusa.com/ and had them replaced at Infiniti dealer. All codes are gone and my car passed the emmision control.
Problem is when I start the car and start driving. It is struggling as if getting choked and after a while runs well. When I try to speed up the RPM goes up high and speed remains the same. Wondering what the problem may be. Never had this problem with my original coils and spark plugs.
Should I take it back to the dealer for a test drive and question them on the installation of the coils and spark plugs.
Please suggest.
Mohiudr
Old Dec 27, 2006 | 12:53 PM
brio_max's Avatar
Learning English...
Check the Coil's part number since your car is made in 2000...
This my old post...:
Originally Posted by brio_max
The Nissan/Infiniti Fast program says:
Part Number: 22448-2Y000, model series-CA33, From-0799 Up To-0600,
App. Model VQ30DE, Specification-RH etc
Part Number: 22448-2Y001, model series-CA33, From-0600 Up To-0701 ....
Probably you've got the wrong coils
Old Dec 27, 2006 | 01:15 PM
mohiudr's Avatar
Part Numbers I used are:
22448-2y000: Electrical - Ignition system - Ignition coil IGNITION COIL, I30, Right, All 2000 (Description from http://www.infinitipartsusa.com/choose.html)
22448-2y005: Electrical - Ignition system - Ignition coil IGNITION COIL, I30, Left, All 2000 (Description from http://www.infinitipartsusa.com/choose.html)
Old Dec 27, 2006 | 01:20 PM
brio_max's Avatar
Learning English...
What is your VIN number and did you tell it to infinitipartsusa...?
Old Dec 27, 2006 | 01:22 PM
mohiudr's Avatar
Yes I gave my complete VIN Number . Model is CA33
Old Dec 27, 2006 | 01:37 PM
i30ds's Avatar
Armed and Dangerous
Has the idle speed been adjusted to spec? Sounds like a bad MAF to me.
Old Dec 28, 2006 | 07:53 AM
I30 Boogie's Avatar
If you haven't replaced the MAF... you should. I have a 2000 base model and jsut replaced coils and plugs. Still had a little hesistation @ cold starts. Replaced the MAF and fixed the problem. As you can read on the forums, the MAF on these cars is notorious for going out. Best of luck!
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
Balkins
Aug 12, 2015 06:39 AM
rhonster
Aug 6, 2015 05:46 PM
maxima297
Aug 3, 2015 12:50 PM
