HID Kit Problem Help PLEASE!
I'm currently running two aftermarket hid kits in lows and fogs.
Today my drivers side fog light stopped working so i tested the ballast and it was fine so i checked the relay and it was rusty and corroded so i replaced it with a brand new relay and it worked. I used both kits thereafter doing some errands with no problem,then after my car being parked for a couple of hours i came out to the passsenger side fog light ON with the car OFF?? I started the car and turned on the headlights and they worked fine but the drivers side fog would not turn on when i turned the fogs on but the passenger fog stayed on even when i shut off all the lights.The only way i could shut the light off was to disconnect the battery????? ANY IDEAS?
Sounds like one of your relays might be defective.
But, more importantly, do you have an auxillary wiring harness (pulling power straight from the battery) going to each of your kits?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
