hid kit question?
Old Jul 24, 2007 | 06:43 PM
rjb22's Avatar
hid kit question?
I have a phillips hid kit and my passenger side light does not go on so investigated and found water in the fatory headlight harness where it goes to the hid harness. I dryed it and still doesnt work so i checked the relay and it was fine,i also checked all fuses and they were fine.What do you think happened or shorted?? thanks
Old Jul 24, 2007 | 09:06 PM
trent.davis23's Avatar
I don't know about the HID part, But make sure you put a bead of clear Silicone sealant across the top of the headlight (where the seam is) or it will just fill back up with water.
Old Jul 25, 2007 | 01:41 AM
MetaOrbit's Avatar
Got Projectors?
Start swapping parts around to the side that does work to isolate the problem. (i.e. swap the bulb, then swap the ballast, etc. until you can determine what is and what isn't working).
Old Aug 30, 2007 | 01:23 AM
maxirider03's Avatar
Yeah seal it up man. Water is bad if your hid aren't waterproof. I got my plug and play from here and didn't have to deal with relays and extra harnesses.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
