Advice on replacing I35 transmission
Old Jun 18, 2015 | 01:22 PM
SleeprLegend's Avatar
I am trying to decide if I will replace the transmission in my I35 myself. After some searching I found that if you know how to pull the c/v axles you can handle the hardest part of the job. Is this true? Is it really all down hill after simply removing the c/v axles?
Old Jun 18, 2015 | 02:25 PM
aackshun's Avatar
Hrmm.
No!
Moving that sumbish up and down would be the hardest part. It's like 150ish lbs.
Overall it's not that hard of a job, pretty straight forward. Time consuming, but straight forward.
Old Jun 18, 2015 | 02:35 PM
haste makes waste
Originally Posted by aackshun
Hrmm.
No!
I had planned on using a jack for moving the transmission up and down. Final alignment might be difficult because of the weight, but I have pry bars for that.
Old Jun 20, 2015 | 06:26 PM
mclasser's Avatar
How many miles does your car have? I also have an 02 I35 and am scared of tranny issues ever since my Accord's one shat the bed a couple of years back.
How do you know for sure your tranny's bad?
Old Jun 24, 2015 | 04:22 PM
I estimate that my car has over 200k on the odometer. When I changed the fluid for the first time about a year ago it looked like it had never been changed. It ran better with regular fluid changes, but now it slips when it gets hot and shifts hard. I found a good amount of metal in the pan on the last fluid change.
CorollaULEV
30
Aug 9, 2021 08:11 PM
jskirwin
Jun 8, 2016 08:49 AM
District
Aug 15, 2015 08:23 PM
Flores94
Aug 11, 2015 12:53 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
