2004 I35 burning oil ridiculously
Old Dec 26, 2023 | 11:03 AM
blkmax1's Avatar
I have a 04 with 162k. Having an oil burning issue what can I do to fix this problem for good. It’s making me consider selling it but it’s a great car. I put some wheels on it and cleaned it up
Old Dec 26, 2023 | 10:39 PM
I35GEEK's Avatar
My 2003 I35 has 185,000 miles. It has been burning oil for a long time. It is common in these cars. I just check my oil every time I gas up and top off the oil if necessary.
How much oil are you burning?
Old Dec 27, 2023 | 11:17 AM
nick's Avatar
My son's 2003 I35 with 130K burns about 3/4 of a QT of oil every 250 miles. No smoke from tailpipe, no CEL, no Valve Cover leaks.
Running Penzoil 10W-40 traditional oil and we installed a ADDW1 catch can and new OEM PCV valve.
Besides that, there isn't much you can do. The only true fix is to swap in a newer engine.
Old Dec 27, 2023 | 11:19 AM
nick's Avatar
How long have you been adding oil? Any CEL or issues with a clogged-up cat?
Old Dec 27, 2023 | 11:21 AM
nick's Avatar
Managed to reduce excessive oil consumption. - Maxima Forums
Old Dec 27, 2023 | 02:38 PM
blkmax1's Avatar
Check engine light on for vent control valve. I add a quart once a week
Old Dec 27, 2023 | 05:18 PM
I35GEEK's Avatar
I have been adding oil for a long time probably the last 100,000 miles. It hasn’t too bad. I add about 1/2 quart every 500 miles or so.
I have no CEL.
Old Dec 29, 2023 | 04:49 PM
blkmax1's Avatar
Went ahead and changed plugs with ngk iridium’s, 6 reman injectors, and coils it feels smoother but I think I need a motor mount when shifting it’s harsh.
Old Dec 30, 2023 | 07:20 PM
nick's Avatar
That's commendable! Any emissions-related issues from oil consumption for the past 100K? such as fouled plugs, clogged cat, CEL?
nick's Avatar
I have no CEL.
That's commendable! Any emissions-related issues from oil consumption for the past 100K? such as fouled plugs, or clogged cat?
Old Dec 30, 2023 | 10:00 PM
I35GEEK's Avatar
No emissions related issues at all. I had to deal with timing chain noise due to broken chain guide a couple of years ago. Once it was fixed, car runs great. For sure, I will reach 200,000 miles soon.
Old Jan 4, 2024 | 10:30 AM
95maxrider's Avatar
Lightly modded
You could always try to add some Marvel Mystery Oil to both the oil and fuel at the recommended concentrations for a while and see if it helps. It can help with sticky rings.
Old Mar 5, 2024 | 02:51 PM
max500's Avatar
try this oil, you will only need 4.2 quarts
AMSOIL
it is rugged, I use it and it is not a cure all but should hopefully cut down oil consumption. The oil some oil change places use is good but I noticed does not resists oil consumption and this has happened in several vehicles I have owned and noticed an improvement when getting a better oil.
Last edited by 95maxrider; Mar 6, 2024 at 06:55 AM. Reason: Edited to remove link, please don't try to sell products without being a vendor
blkmax1
May 30, 2025 01:13 PM
IloveI35
Aug 30, 2024 08:52 AM
cwaters1184
Apr 15, 2013 07:27 PM
SlyI35
40
Nov 11, 2011 10:32 PM
