to all the engine guru's
Old Sep 3, 2002 | 08:16 PM
bosco500's Avatar
i replaced my injectors today and cant get my car cranked. i got to looking and i left the o-ring out that goes under the bolt that holds down the fuel rail. would this cause it not to crank? i dont want to have to pull that damn manifold off 3 times if its bad injectors.
Old Sep 3, 2002 | 09:05 PM
SuDZ's Avatar
Re: to all the engine guru's
Does it even start to turn over or nothing happening at all?
SuDZ
Old Sep 3, 2002 | 09:07 PM
nismo2020's Avatar
Needs non-Maxima Friends
got any ecu codes?
like sudz said does the starter crank or no, can you push start it? (primitive)
Old Sep 3, 2002 | 11:14 PM
zntema's Avatar
did u check to c if any fuel is goin into the injectors?? This car that i worked on, where the fuel enters the fuel rail had a hole inside the screw to let fuel from the fuel line to get into the injector rails. U need to make sure that the hole inside the bolt is aligned with the fuel hose goin into the rail. Also check your spark plugs to see if it sparks or is it wet.
Old Sep 4, 2002 | 04:26 AM
bosco500's Avatar
the starter turns over... just doesnt crank. it sounds like it wants do, but it just doesnt.
Old Sep 4, 2002 | 05:54 AM
njmaxseltd's Avatar
If your starter is "turning" and engauging the fly wheel, your engine is "cranking" over but not starting. Please clearify this for us.
You have a crank, but no start condition?
Old Sep 4, 2002 | 06:18 AM
bosco500's Avatar
sorry to be so vague. i'll try again. the car is cranking, just not starting. it cranks at 50 psi of f.p., but when i stop cranking, the f.p. drops at a rate of about 1 psi per second. i re-checked all the fuel lines and everything is tight as can be. i'm hoping that the black plastic spacers that i left out are the cause of this. i just dont understand how it could keep it from starting, unless the injector is pushed too far down. would these plastic spacers also be the reason of the fuel pressure loss? should i get new o-rings for the injectors?
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
