Home Depot Gutter Guard Grill Question...
..where would I get a U-gasket or something similar for covering the sharp edges when making my own Home Depot Gutter Guard Grill? I think that grill-tech uses a U-gasket (basically a rubber "track" that the metal grill goes in so it doesn't scratch the paint).
Re: Home Depot Gutter Guard Grill Question...
Gutter Guard?
Can this be done with a professional look?
I have no idea....really, ask anyone, i'm clueless...
-vq
When I did it, I just did it behind the valence...But after going to home depot to get some weatherstripping to fix the rattle in the rear deck of my girlfriends car, I think you could use some of the heavy duty rubber weather stripping...You could easily mold it around the mesh and it comes in clear too...so it would hardly be visible
Good luck.
AA
Re: Re: Home Depot Gutter Guard Grill Question...
Originally posted by doublea
Hey spta97, I found some door edge molding, it's call TrimBrite made by Spartan Plastics Canada ltd, I bought this at Canadian Tire for 10$ the good thing about these door edge is they have some glue in it and there available in black - chrome - gold and many other colors. I made my grill almost 1 year ago and it is in perfect condition, the only thing is I was unable to find a lenght over 27".
Good luck.
AA
Good luck.
AA
Originally posted by 00MaxSE
When I installed mine, I stuck in up into the splash gaurd under the car and zip-tied it to the vertical plastic pieces. It fit perfectly and didn't have to worry about scratching the paint.
A-
That's a pretty good idea. I should have thought of that before putting the gutter guard on my grill. Unfortunately, I was so exited about seeing how it was going to look, that I just placed it in between the horizontal bars of the grill without thinking about the possibility of scratches. So needless to say, I have a few scratches on my main grill. It really isn't necessary on the valance. I cut the valence just a bit small so that wouldn't happen.
Here's a pic of my grill and valence.
Check out more pics on my home page.
Originally posted by VQMAN
I have no idea, but I wanna see pics when you're done...
Gutter Guard?
-vq
Gutter Guard?
-vq
Originally posted by MadMax1996
What about the automotive trim that people use on the edges of their doors? I've seen it in black & clear.
Good luck.
AA
Good luck.
AA
Originally posted by Andrew
would the zip ties start to wear on the vertical plastic pieces? The pieces are painted...no?
A-
A-
Here is a pic of what the aftermarket one by Grill-Tech looks like:
It might be worth it to spend the $60!
Originally posted by 2M0A0X2
hello?
hello?
I basically took the home depot gutter guard mesh and cut it into the small sections you see in the pic. The best way is to use cardboard to make templates of each section and then cut the mesh from that. I cut the mesh about .5 to 1 inch larger than the template, and bent the excess mesh.I tried to bend all the angles so that the bent sections went into the grill. This way it has a bit of a 3D look when looking at it from the sides. Then just paint it whatever color you want, and voila! Using small zipties will hold it in place.
Sorry, must have missed your post! Wasn't trying to ignore you.
whoa, thanks a lot man, i gotta try it on a 2k2 now...maybe today or tommorow...5 day holiday for me!
Some suggestions...
Try and find some type of "rubber" track that spta97 started the thread about. It would prevent your grill from getting scratched up.
Also, get some kind of heavy duty wire cutters, otherwise, your hands will hurt from all the cutting
[QUOTE]Originally posted by Hotnicks
I like that idea as soon as it gets wormer here in Chicago I will try it and if it doesnt work on my 2k2 Ill just try and put it over the stock grille. It beats paying $200 for the lower vellence and grille
Neal728: Look at the pic posted on the first page of this thread (Kloogy's car I believe). You can do something similar with the gutter guard.
2M0A0X2: Have you tried this, how did it turn out? I'm curious to see how it came out for you...
no, i haven't tried it yet because this weekend, it was cold up here in the north, home depots here don't have gutter guards....lmao, u wanna send me some?? haha, yeah, so i gotta look around at other hardware stores for it.
REDinLV
Aug 15, 2024 12:30 AM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
