Those with RVM Pulley
Old Mar 6, 2003 | 12:08 PM
97MaximaSE's Avatar
I just want to know, since ive seen so many different part numbers and belts when i search, which is the best one everyone has used. I really dont feel like buying 6 different types of belts and trying them all. Thanks
Old Mar 6, 2003 | 12:11 PM
slavik'sMAX's Avatar
I just bought belts from nissan dealer......oh and another thing, one of the belts which RVM install instuction mentions is too short, I forgot which one though
Old Mar 6, 2003 | 12:19 PM
xHypex's Avatar
Double check the part #s because I'm not sure if the RVM and PR UDPs use the same belts (they probably do). Also check your belts when you buy them: I was given a belt with the correct packaging but the WRONG belt.
From
http://forums.maxima.org/showthread....&highlight=UDP
While we're speaking about belts I bought 3:
Alternator & Water Pump
1995-02 Gates # K060408
Power Steering
1995-02 Gates # K040292
If this one does not fit then try: Gates # K040300
I tried to fit the K040292 and there was NO way it would fit. I ran the adjuster all the way down and it was still too tight to fit on. I used the K040300 with no problems though
-hype
Old Mar 6, 2003 | 01:52 PM
Sprint's Avatar
jooooooooooo suckkkkkkkkkkkkkkkkkkkkkkkkkkkk
Old Mar 7, 2003 | 10:48 AM
97MaximaSE's Avatar
so is that the part number im looking for???
Old Mar 7, 2003 | 01:46 PM
Sprint's Avatar
i don't think so..
Old Mar 7, 2003 | 01:49 PM
Jamsan's Avatar
6PK1045 and 4PK 760
Bando part #'s....can go to napa's website and put in a cross reference for other brands
Old Mar 7, 2003 | 01:59 PM
hacim105's Avatar
well neither of the first 2 fit my car. I had to get the K060410 and the K040300.
K040292 is too small. And K060408 may be too small also. Just buy all four and return the 2 you don't need. That's if you have a local dealer of of the gates belts. But the nissan OEM powersteering pump belt fits the RVM.
Old Mar 7, 2003 | 02:13 PM
97MaximaSE's Avatar
Originally posted by Jamsan
6PK1045 and 4PK 760
do you have yours on yet jaime? how do you know they work
Old Mar 7, 2003 | 02:17 PM
Jamsan's Avatar
it's still in the trunk with my rsb
sterling99se (i think?) has it installed on his car, and those are the belts that he used, and they fit fine
Old Mar 7, 2003 | 04:29 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Also...
Did anyone who recently purchased the pulley from the GD get a "stainless steel oil sleeve"?
In my instruction sheet it says "Check to see that stainless steel oil sleeve is mounted to the rear of the pulley". I am assuming that its like the inserts UR includes on their pulley for the crankshaft oil seal. However the pics I've seen of the RVM pulley people have posted during their installs doesn't have it (like mine). Am I missing something here? Is he coming out with Version 2 and we got stuck with the lesser ones ?
Also the surface that rides the oil seal isn't perfectly smooth too.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
