Really thinking about getting the MSD RPM Switch
Old Apr 30, 2003 | 12:23 PM
deezo's Avatar
I know its more and not as variable as the Harlan (which I have) but I have more confidence that it will work all of the time.
I talked to a rep at MSD yesterday and they tell me its about $35 to modify it to work with our ignition setup. I'm willing to kick a little more $$$ to get something that's going to work.
I'll most likely sell my harlan to get the MSD. I've found one for a very good price.
Old Apr 30, 2003 | 02:19 PM
matt calder's Avatar
It does, I have had mine taped to my battery for almost a year and have had no problems whatsoever.
No headaches here.
Old May 1, 2003 | 05:20 AM
deezo's Avatar
No headaches here.
You had yours modified?
Old May 1, 2003 | 05:29 AM
mzmtg's Avatar
Minister of Silly Walks
I think the Harlan/Relay setup will be more reliable if you mount it inside the car instead of under the hood.
https://maxima.org/forums/showthread...hreadid=211332
Old May 1, 2003 | 05:36 AM
Confused's Avatar
Permanent Maxima.org Resident
either way its May.. time to install that bad boy.
Old May 1, 2003 | 06:11 AM
ejj's Avatar
ejj
I had my harlen window switch under-hood for my nitrous setup, and haven't had a single problem.
Old May 1, 2003 | 06:33 AM
deezo's Avatar
Yeah, you're right.
I'm still searching out a couple of parts and I was busy with the family and work for the last few months. All I need is the vacuum canister and I'm golden. Can't find that bish anywhere.
Old May 1, 2003 | 09:28 AM
It had already been modified when i bought it.
Old May 1, 2003 | 11:28 AM
Krash513's Avatar
Re: Really thinking about getting the MSD RPM Switch
I was looking at the MSD too, and saw that they have a dial modulator selectors that would make it act very much like harlans. Only bad part is its like 40 bucks... but it might be worth it for the ability to change the rpms.
Old May 1, 2003 | 01:21 PM
deezo's Avatar
Re: Re: Really thinking about getting the MSD RPM Switch
That's right.
It would cost much more in the end but at least you would be getting a highend piece of equipment (no disrespect to harlan's workmanship).
Old May 1, 2003 | 02:53 PM
Krash513's Avatar
Re: Re: Re: Really thinking about getting the MSD RPM Switch
That's right.
Right, if i was gonna spend that much money on the VI, i would say spend a little more to make sure that it works 100%. When i had my VI on order i was planning on going the MSD route, but sadly no more
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
jfl330
Sep 4, 2015 01:44 PM
dcardello
Sep 3, 2015 11:44 PM
