a'pexi S-AFC helps u pass smog test???
If he was running super rich then leaning it out would make less fuel go through. So I guess theoretically, yes
But on our cars the ecu resets if you set the high to anything lower then 50% I believe. I dunno if during a inspection they give that much throttle?
It might. But if you car is na and you can't pass smog, then there's something seriously wrong with your car to start with. The safc would just be a bandaid fix. Not the real way to good emissions or real hp.
In some cases when we get a car with too many miles, that was poorly maintained ans has alot of carbon buildup, it is harder to get it too pass. If you fail by just s little bit, even an oil change and coolant flush alone could easily help you pass. Today we mad a 92 Ford truck pass but doing a oilchange and retarding the timing 6 degrees, then after it passed returned it back to normal
Messing with the timing that much isnt a good idea for the max.
for what Jeff said, but sometimes you gotta do it.
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
