Emblem Shaving
Emblem Shaving
I understand how to do it. The problem is that i worry that my 96' Maxima GXE will leave a stain or the paint is burned in. I am worried that the MAXIMA will leave an imprint in my sterling mist paint. Should i worry about it?
just remove the emblems, remove the glue with some goo gone (worked well for me). then go over it with a buffer, there MAY still be slight color difference, but that should soon vanish, and worse case, you have to put the emblems back on...
Yeah, pretty much. My friends 96 had that happen, if you look at it with the right light hitting it a certain way, you can still make out MAXIMA, but you have to know what your really looking for. Thats why i just shaved the burger off, and left maxima...
Eric
Check out the "Regional" forums
I'm about to do this on my white Max and I know it'll leave an imprint on it. It should go away after a while, if you wash and wax it normally.
I tried it a few weeks ago, but the fishing line broke
Need to find a stronger fishing line...Atleast take off the Nissan hamburger in the back! I'm taking off everything in the back since my emblems are gold and now they're dirty and gay looking. For me, it'll look better with it off
Just like ch13f said, the worst thing would be is that you would have to put them back...
ok now that i have removed it, i can see little remains of the m's and a's. Is there anyway to get rid of it? I cleaned the adhesive off so now what should i do. I can see these m's and a's outlines at certain angles.
Maybe the sun will eventually burn those colors in?!
Try using a clearcoat polishing compound to clean it up a bit. This made my rear look flawless and you can't tell any of the emblems were there on my 95 pbm max
you should be able to find this at any 'everything store' like walmart or kmart etc.. if not, you can find them at any auto part store
How did you do it?
Originally Posted by Vlad
Thank you maximumspeed!!! That a good idea, I tried to use fishline today that found in the garage, but it kept ripping. Dental floss should work!!!! Will do it tomorrow!!!
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
rbaker100
Sep 6, 2015 02:46 PM
but i think its b/c i rubbed so long and hard and used dare i say it.......a paper towel
, what is the best way to take those emblems off, not pry them out I guess..
