8.989 @ 80mph
Old Apr 6, 2004 | 06:17 PM
MaxSpeedSE's Avatar
8.989 @ 80mph
I went to the 1/8 track tonight with my girl to mess around with my nitrous kit
My setup for tonight was...
95 SE With 5 speed converson
NX wet kit - 35 shot
RVM intake pipe with Stillen popcharger ( warm air intake )
Custom cat-back exhaust
Buget Y-pipe
Exedy Clutch
- Stock Struts / shocks with sprint springs
Was rolling on 17 inch Konig Monsoons with STREET tires @ 25 psi
-Best run-
R/T: .805
60' : 2.188
330': 5.968
ET: 8.989
Trap: 80.11
I did not think i had a chance of breaking 8's with street tires .. I just found a preaty good way to launch it and was putting down good times. Lots of wheel hop tho... Any feed back would be good. I wanted to try a 50 shot and drop the tire pressure to 20-15psi but the track was closing, maybe next time
-Chris
Old Apr 7, 2004 | 06:42 PM
CullenJ76's Avatar
excellent 60' for street tires!
are you spraying out of the hole or what? I'm in the middle of figuring out when to start spraying. I'm launching w/o n2o, but start spraying about 1/2 way through 1st. So far it's netted me a 8.7 @82.4 2.11 60' with the same setup you have. I'm impressed by the 60' on street tires.
Old Apr 7, 2004 | 08:10 PM
MaxSpeedSE's Avatar
Our setups are the same beside the UDP, you have better tires, and upgraded suspension... u have aftermarket suspension correct? I want to upgrade because I herd that helps a lot.
The way i launched was spraying out the whole from the very get go... I had the rpms at 2 grand, when the light hit green i just popped the clutch and floored it.. I was spinning and getting wheel hop all the way threw 1st gear, it felt awful but on time slips it was working.. I think I can even put a faster time because I had problems with my 1-2 shift… my rpms were hard to read since I was spinning so much and when I shifted sometimes it was too early and I was out of power band in 2nd gear
RI-2k2
Oct 30, 2002 09:51 AM
rerunn
28
Oct 16, 2002 04:09 PM
AuxNuke
84
Sep 26, 2002 06:54 PM
hokiemax
Aug 13, 2002 09:12 AM
QUANSUNG
40
Dec 5, 2001 09:43 AM
