how aobut cv joins replacement?
Old May 8, 2004 | 08:00 AM
Kbuitre's Avatar
as anybody replace theirs?
is expensive and i wonder if i can do it my self... ?
any tips will help.
Old May 8, 2004 | 08:50 AM
MAX_POWERS's Avatar
I wil be replaceing mine ,maybe today.It's easier to just replace the whole half shaft.It's also cheaper then just buying the cv joint by itself.The half shaft is about $70 with core exchange.It comes with both inner and outer cv joints.You need to remove two bolts connecting the strut and the spindle and remove the tie rod and sway bar end link.You should be able to pull out the half shaft out.It's not that hard of a job.
Old May 8, 2004 | 09:14 AM
Kbuitre's Avatar
any special tools?
Old May 8, 2004 | 02:44 PM
MAX_POWERS's Avatar
Just a tie rod seperator ,some socket set ,and hammer.
Old May 8, 2004 | 02:46 PM
SkinnyMax's Avatar
maxima no more
and a 36mm socket to get the axle nut off
Old May 8, 2004 | 03:39 PM
Taken2DaMax's Avatar
Do these yourself, you might have to end up paying to replace these at $110 each like my dumb@ss did.
Old May 8, 2004 | 05:45 PM
Magikone69's Avatar
are there any performance type drive axles for us. im not looking for something to increase power but i want something that is strong and built to last. i purchased a set of axles 3 years ago and they are already clicking and the boots are perfect. worst part is the warranty was only for a year so i need a new set. any good performance axles and how muc are they, i believe raxles.com has some. does anybody have them or know abouth them...?
Old May 9, 2004 | 05:08 PM
sryth's Avatar
A good breaker bar to go with that 36mm socket as well.
Don't get the fork/wedge shaped separator unless you want to tear the boot. I use a 2-jaw puller, while others don't even disconnect the tie-rods.
Old May 9, 2004 | 08:23 PM
Max Noob's Avatar
if you cv joint has been leaking for a while..and its dry in there.i would have the whole axcel replaced with a rebuilt one.. cost of the rebuilt axcel is liek 115 bucks.. u shold be able to take it off and put it in yourself if you mildy mechanically inclined
Old May 9, 2004 | 08:25 PM
Try getting a hold of Ceasar. I think that he has some performance axles.
PH98I30
29
Feb 10, 2025 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
crazyespn
Sep 3, 2015 01:30 PM
