HELP! Can't go over 30mph!
Alright, so after I got my new engine swapped back in I finally decided to take it out for a test run. . . BUT! The car won't go past 30mph. . When looking at the RPMs, I will hit 1800 rpm and then the engine sounds like its cutting off my fuel or something. I step on the gas, but it's as if I hit the rev limiter? Does that make sense? HELP?! What is wrong with my car?!!!!!
I had this exact problem I had totake it to a professional and he got it running. He said something about a choke mechanism by where the throtle cable is at. I will try to go down to that shop and find out exactly what he did.
Thanks for the help in advance. .. .
1. I don't know what limp mode is. can anybody elaborate?
2. Yes the rev bounces at 1800 . . . it goes up to 2000 then drops back to 1500...
Originally Posted by kevlo911
Reset hte ECU and see what happens.
TPS? IS that Throttle position Sensor?
I dunno, but i dropped the car back off to my mechanic and I guess we'll see what's up. Also discovered that my car is blowing out smoke through the exhaust. Perhaps I'm running too rich? Dunno cuz my SAFC is not installed yet.
To check the TPS, open the TB butterfly plate all the way and disconnect the BROWN connector on top of the TPS. Now using a multimeter check if you have around 4v between pin 1 and 2 on the TPS not the brown connector.
Originally Posted by PmpLuxCEO
OK, reset the ECU, got a 0505 A-OK all clear,nothing wrong. . .
Hey Will,
Still not up and running right yet?! Maybe I'll come drop by, let me know when you are free.
Jonathan
What is bizarre is that the car idles normally with the TPS plugged in, but wont rev past 1800 rpm. If I UNPLUG the TPS, it idles at 1800 RPM, but revs up and drives normally (besides the fast idle). Stop the car and throw it in neutral, and it idles back at 1100. Throw it in gear (still stopped) and it pops back up to 1800. I DID clean the IAVC (was severely carboned), but no effect.....
Stickies? :-)
It doesn't sound like a MAF issue because when my MAF when out I had a bunch of codes, too lean, too rich, bank one, bank two. Basically a mess.
And my car wouldn't run pass 3K RPM.
But your problem doesn't sound like something is physically stopping your throttle but more like a safeguard or something stopping it. Perhaps the TPS is on its way out? Like when you step on the gas its only reading a certain voltage and staying there instead of increasing as you step harder on the pedal.
EDIT: Whoa, I completely thought that viking1 was the OP since you guys had such similar problems! After some more thinking it still puzzles me. Since what ever is stopping the car from going over 1.8K RPM is cutting off fuel or air, but not too sure if it affects spark. And the only things that do that are sensors or maybe its actual injectors themselves not spraying enough gas to go over 1.8K RPM. Could the ECU screw affect or limit our RPM? Maybe its not turned all the way to one side or something.
PCV?
no leaks in intake piping. U prolly have a crapped out MAF man.
I'm having the same problem,my car at fist would bog down after 2000 rpm's.Now after a few days it dies when I give it gas.Many have said it might be the MAF?I hope it is,I just ordered one.(Sorry for the high jack)
Is there a specific test for the MAF? I guess I could use the search function (LOL). I DID clean the MAF sensor with proper MAF cleaner. Is there something else besides the sensor that goes out? Didnt change a thing on the ECU.....
Hondarydr
Dec 30, 2024 06:15 PM
Mmmaxx
Mar 14, 2004 07:58 PM
Craig Mack
Sep 13, 2002 12:33 PM
