Seems I broke a rear strut.
STUPID POTHOLES! but i can't find any write-up for replacing the rear so i was wondering is it basically the same as the fronts? are there any isssue i should prepare for. plus whatt all part do i need beside the strut? Thanks
i broke some important bolts by over-torqueing
tools:
17mm socket 1/2 drive, with ratchet and breaker bar
12mm deep socket 3/8 drive and ratchet
14mm wrench (ratcheting one works perfect)
adjustable wrench
spring compressor with appropriate socket
adjustable wrench
You actually don't need a spring compressor to do the rears. There's not much preload at all. Let it pop off, then have a buddy hold pressure on the spring to put it back together.
