Buzzing noise from tranny area.
Old Jan 6, 2005 | 02:33 PM
Kevlo911's Avatar
Kevlo for President
Alright, I need someone with an Auto tranny to check something for me. Turn the key so all the dash lights are on. Then pop the hood and move the throttle open and see if your car makes a noise. Mine does and I don't know what it is.
Old Jan 6, 2005 | 02:35 PM
DonOfDesperados's Avatar
mine makes a buzzing/whining noise when the car is on and i turn i have yet to figure it out
Old Jan 6, 2005 | 05:50 PM
Black Maxima
Mine makes a fast buzzing/clicking noise when I have the key turned so all the dash lgihts are on, but the motor isn't running. Sounds like it's comming from the under the motor. This usually happens when I have the radio on for a couple minutes without the motor running.
Old Jan 17, 2005 | 07:09 AM
Kevlo911's Avatar
Kevlo for President
B-u-m-p.!.!.
Old Jan 17, 2005 | 09:28 AM
Kevlo911's Avatar
Kevlo for President
Can you explain further?
Old Jan 17, 2005 | 09:32 AM
2 Da Max's Avatar
what made you open the throttle like that when the key is in??
Old Jan 17, 2005 | 10:15 AM
Kevlo911's Avatar
Kevlo for President
I am installing something in my car, and when that is plugged it, it always makes the buzzing noise. So I tried to duplicate the noise and it does it when I open the thottle when key is in the ACC position(even when the thing I am installing is not in).
Old Jan 17, 2005 | 03:21 PM
Debade's Avatar
Maybe it could be the fuel pump building pressure in the lines?
Old Jan 17, 2005 | 03:35 PM
cw96's Avatar
You got my curiosty up so I just went out to try this on my car.Popped open the hood,turn on the switch, then open the throttle and i'll be dam*ed if mine didn't make a buzzing noise also from somewhere near the tranny.It only does it when the throttle is opened up. Don't know what it is though because it is in the teens outside and I didn't want to freeze my butt off trying to figure it out.I will be checking into this myself though when I can get some space in the garage just to know what it is.
Old Jan 18, 2005 | 12:38 PM
Kevlo911's Avatar
Kevlo for President
I am glad someone else has the noise too, now I need to figure out what it is and why the noise stays on when I have my special electrical thing in.
Old Jan 18, 2005 | 01:24 PM
lex4style's Avatar
i think its the alternator...mine does the same thing when the keys are turned and my lights on my dash are on. hmmmm not sure....
Old Jan 18, 2005 | 01:41 PM
Kevlo911's Avatar
Kevlo for President
No, it's comming from tranny area....
Old Aug 18, 2005 | 10:16 PM
HarrisH's Avatar
Mine's doing the same thing but throttle does not make a diff., also when the car is started and idling in forward moving gears it makes that sound.
Old Aug 18, 2005 | 10:33 PM
tweeter007's Avatar
I had noticed the same thing last summer, after driving around and tranny was hot I would hear the buzzing noise whenever I was not in drive, would hear that sound in P and N only. Couldn't figure it out, have not noticed again in a year!Make sure your trans fluid is at the proper level.
Old Jul 22, 2011 | 01:48 AM
Mnick1's Avatar
I am sorry for raising the dead on this but has any of you found out what the noise is? I've had it too for a couple of years but it doesn't seem to have any effect on my battery voltage, well I really can't say for sure if it has or not. Just wondering if there was an answer so I can rule out fixing it or worry about it. Please let me know
Old Jul 22, 2011 | 05:53 AM
Kevlo911's Avatar
Kevlo for President
nope i dont even remember it and now i have a manual
Old Jul 22, 2011 | 12:18 PM
cashoit's Avatar
o snap i didnt even see the orig date on the thread. Might have been VSS or bad DR
Old Jul 23, 2011 | 03:03 PM
Trini Boom's Avatar
Funny that I read this thread a few days ago and I heard the same noise today. I had my car up on stands to check oil leak and i heard the buzzing noise. I went under to trace the noise and it was coming from inside the tranny oil pan which may indicate the solenoids. When I turned it off and turn back to on without starting the noise wasn't there.
Old Jul 23, 2011 | 05:00 PM
Mnick1's Avatar
This the strangest thing... Even more strange is no one has provided an answer for it yet. Tons of questions about it but no answers! Mine sounds like it's the starter. My starter is fine plus I have a ground wire attached to it. It made the sound even before I added the extra ground. What solenoid are you referring to? Mine comes on every time I turn the key and stays on til I turn the key off. It's definitely not the fuel pump or IAVC. I hope somebody can shed some light on this..
Old Jul 23, 2011 | 07:08 PM
Trini Boom's Avatar
There are shift solenoids inside the tranny located near the oil pan. I think there are 5 in all. Yes, the noise occurs when the key is left in ON position without starting. Doesn't seem to be a major issue if you ask me.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
uttadms31
Sep 30, 2015 05:24 AM
