Bucking around 2000 rmp
Old Feb 26, 2005 | 01:13 PM
91max's Avatar
My '91 Max idles great, starts fine but when you give it some gas, either in park or while driving the thing starts bucking real bad like it wants to stall but dosn't. As sone as I back off the gas and ease into it, it runs fine until the rmps get up there a bit and it want to cut out. This only happened a couple intermited times.
The plugs, wires etc have all been replaced.
So, I replaced the fuel filter, air filter, cleaned the MAS and added dry gas in the tank, filled up with super, and now it does it all the time!
Any advice would be great!
Thanks,
Old Feb 26, 2005 | 03:49 PM
MAXI's Avatar
Thanks,
try getting codes by running diagnostics.
Old Feb 26, 2005 | 03:56 PM
mtnbikeair's Avatar
Maybe its missing...
Old Feb 26, 2005 | 04:43 PM
Chris Gregg's Avatar
Get Off My Lawn
Did you clean the MAF before or after it started doing this. Sounds like MAF to me.
Old Feb 26, 2005 | 05:48 PM
internetautomar's Avatar
mod or sell?
do the RPMs get above 2k?
Old Feb 26, 2005 | 10:51 PM
bvtran's Avatar
94c Big Max
yeah I am having the problem now with my max too it just ******* and sleazing and wouldn't go over 2k rpm. is there a way to clean the maf sensor cuz this thing's expensive.
Old Feb 27, 2005 | 12:06 AM
Wiking's Avatar
Ask internetautomator for better price... There is nothing to clean. Only two resistors for u to ruin.
2000rpm is safe mode limit when some sensors fail; like cam rev sensor.
Look at sensors testing from autozone.com
and http://www.cardomain.com/memberpage/748507/9
Old Feb 27, 2005 | 09:04 AM
91max's Avatar
O.k., I find that it has a code 12.
Haynes said to check for for to the MAF, it was good. Then it said to check terminal "B" while at idle and engine off, key on. I got nothing. So, now what do I do?!
Old Feb 27, 2005 | 09:47 AM
Wiking's Avatar
1. Read. Then click and read. Then tst.
Old Feb 27, 2005 | 01:26 PM
91max's Avatar
Wiking I don't get it?
Old Feb 27, 2005 | 10:15 PM
maxima93gxe's Avatar
try testing your oxygen senor/knock sensor
all you have to do is unplug the senor conector, check the manual for location. drive the car around and see if the problem goes aways.
this problem happen to my 89 gxe (vg30) thought it was the maf sensor too
Old Feb 27, 2005 | 10:30 PM
Wiking's Avatar
I have compiled 'some' info on my web page for shooting down problems like u describe. You dont get it as you dont read it. Please get it. One gets it by clic king here on the link I gave already. Btw, t here are many pages for u:
CLIKCK ON ↓↓↓
http://www.cardomain.com/memberpage/748507/14 ...etcetc
...like what maxima93gxe said: "try testing your oxygen senor/knock sensor
aaand ---> try bypassing your oxygen senor/knock sensor
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
