how to install eyelids on a 96?
Old Mar 1, 2005 | 06:59 PM
danger's Avatar
hey does somebody know how to install eyelids on a 96? what i do with the little nipple on the headlight because it stick out a little ok if somebody know to let me know at ojs81@hotmail.com ok thanks
Old Mar 1, 2005 | 07:01 PM
2 Da Max's Avatar
i had to take a file and a lawn chair and start sanding. then i got tired and got the drill out with a sand paper type wheel and just start grinding it down. takes about 20 mins the most on each side
Old Mar 2, 2005 | 02:01 PM
FormorAccordMan's Avatar
I believe those nipples are used by special headlight aiming machines/
Old Mar 2, 2005 | 02:03 PM
risingmist's Avatar
i took off my nipples with a dremel and a tungsten bit. make sure to use a little water or it might get too hot.
Old Mar 2, 2005 | 03:33 PM
Flava_24/7's Avatar
Boosted Panda
I also used a dremel, but I used a diamond cutting wheel which cut through it like Butta...
Old Mar 2, 2005 | 04:49 PM
RicoSuave98's Avatar
hey flavor- where did you get the lid for the corner light. that CF look is hot
Old Mar 2, 2005 | 05:54 PM
Flava_24/7's Avatar
Boosted Panda
IonicDynamics
http://www.ionicdynamics.com/Eyelidnew.html
Old Mar 2, 2005 | 06:10 PM
Doc's Avatar
Doc
Gr8 blend with your CF hood. Nice look.
Old Feb 27, 2011 | 06:13 PM
VQ'rInWLA's Avatar
Age old bump...Didnt wanna start another thread.
I tried to mount my eyelids with double sided tape (not 3m) but it seemed too bulky. It wasnt flush with the lights. Are there any alternative ways to mount em? Something that would withstand the heat from the HIDs.
Old Feb 27, 2011 | 06:26 PM
Use 3M playa. That's what I used and it was perfect. It withstands heat nicely as well!
Use the heat from your HIDs to mount the eyelids though, it'll make them stick a lot better and they won't come off.
Old Feb 27, 2011 | 06:53 PM
VQ'rInWLA's Avatar
Are they thinner than the typical double sided tape? Ill check em out.
Old Feb 27, 2011 | 07:07 PM
VQ'rInWLA's Avatar
http://cgi.ebay.com/ebaymotors/6377-...d=190279826474
Is this what I should be looking for?
Old Feb 27, 2011 | 09:01 PM
Yup that's the stuff. Just get it at your auto parts store they usually have it there.
Old Feb 27, 2011 | 09:08 PM
VQ'rInWLA's Avatar
And theyre thinner strips right? I want em flush with the lens.
Old Feb 27, 2011 | 09:34 PM
They're pretty thin compared to other double sided tape I've seen. Plus once you let the heat set in and push down on the eyelids real good the tape will flaten out a little more. You'll see bro.
Old Feb 27, 2011 | 09:36 PM
VQ'rInWLA's Avatar
Ight Ill pick some up tomnorrow. Good looks.
Old Feb 28, 2011 | 04:06 AM
95Maxed's Avatar
I made custom Eyelids. Used 3m Carbon Fiber Vinyl. They look pretty good and stretch over the nipple.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
