Wierd noise from right front wheel
ok guys, i recently lowered my car with D2's. And now when i make a sharp left turn, the right side of my front wheel is making this clunking noise. its realyl wierd, anyone know what this could be or know how to fix it? i thoguht it might be my hub bearing, but i checked it and the boot looks great, no leaking oil. maybe the rotor?? and yes i made sure all my lugs are tight. seems like i can't fix the problem. i get a lil worried cause i don't want my axle to break off when i'm turning, that would be bad
Clicking noise when you make a sharp turn
It sounds like your CV joint bearings are bad, even if the boot is intact, they still may be damaged. Try replacing the bearings or even the entire axle. Keep it cleep and if it doesn't fix the problem, pull it out and return it.
boomerbrian
Nov 8, 2015 05:10 PM
BassAddictJ
Aug 4, 2015 11:38 AM
