Wheel Bearing Help
Wheel Bearing Help
In the process of trying to replace front wheel bearing. I have removed the caliper, rotor and axle nut. I assume the next piece to come off is the part with lugs.
Before I tear something up. Do I need a wheel puller to remove that piece? Or am I going about this wrong?
Thanks!!
Thanks!!
you need to remove the 2 bolts holding the wheel hub (big part with lugs) to the strut (tall shaft with spring)and the cotter pin and nut holding the steering tierod to the hub and the 3 nuts holding the ball jiont to the hub (ON THE BOTTOM)
then you have to press the old bearings out and the new ones in or take it to a shop and have them do it or if you want to you could come down and i could help you do it (i have a press and have done my wheel bearings)
londonflu
40
Sep 25, 2015 09:11 AM
