Noise In Engine Bay?
Hey I have a rattling coming from what it sounds like the right wheel well. When I hit the gas around 1G to 1.5 RPM it sounds like its coming from the some where around the belts or swing arm but im not certain since its only makes the sound well im driving and when i first hit the gas in 1st gear any idea's guys?
check your belts and make sure none are loose or not seated properly. Also park your car, turn it on and pull on the throttle wire to see if you hear the noise. if its only while you are driving then check your around your right front wheel, does it make noise when you turn?
ballerchris510
Sep 11, 2015 05:29 PM
