dashlights that blink on for a split second after starting up
Old Aug 10, 2005 | 10:13 PM
kbmaxima's Avatar
so i'll be starting the car up in the morning. it'll crank *hesistate* and with an almost forced cough, the engine will start. once it starts the oil light blinks for about half a second. this happens at every startup. intermittently, the O/D off light will stay on for about a second after startup. I let the beeps beep away before starting my car. Is this something of concern?
99 gle with 99k
ngk plats and fuel filter with 15k on them
clean tb & maf; paper filter with 3k on it.
new battery
Old Aug 11, 2005 | 08:04 AM
99Automagic
99 gle with 99k
new battery
The O/D light stays on for a short period, that's a normal thing. The blinking oil light, I am not sure of. It usually happens when an engine is running rough, but there could be a million causes for that. Have you checked for any codes?
One more thing, check your oil, make sure it's not low.
Old Aug 11, 2005 | 09:04 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
thats normal .. if the oil light stayed on after startup then i'd worry
Old Aug 11, 2005 | 09:11 AM
PAREDLINE's Avatar
yeah my oil light pops on for a split second too
99Automagic
Normally the oil light does not blink. That's what concerns me.
Old Aug 11, 2005 | 11:24 AM
Jatan's Avatar
Check: http://www.motorvate.ca/mvp.php/514
Old Aug 11, 2005 | 06:59 PM
kbmaxima's Avatar
interesting. thanks guys.
Old Aug 11, 2005 | 07:40 PM
RA030726's Avatar
I'm nutty for Nissans
the oil pressure switch needs to hit a certin pressure to go out and it takes time for the oil to reach the switch. alas its normal.
Old Aug 12, 2005 | 05:50 AM
Norm_Nav's Avatar
yeah me too!!!!
My dash lights kinda blink for a while when the key is in the on position (prior to cranking the engine) then when I crank the engine, the starter engages, but the engine fails to start, it may or may not cough, then when I try a second or third time, it comes to life, all lights go out and it purrs like a kitten. I'm new to this car(1996 infiniti i30), so haven't become familiar with it's pecadillos. I have changed the starter and oil, but I only used four quarts (manual calls for 4.4) but the oil level is disgustingly difficult to read and I'm afraid of overfilling. One other thing,, the sound diminishes on the radio/cd when I apply the brakes or turn on the lights...i'M THINKING ELECTRICAL!!.....AS AN ASIDE, THE CAR IS A WONDERFUL DRIVING EXPERIENCE,,
shilov
Feb 19, 2024 09:40 PM
QueensMAX
Sep 15, 2015 04:14 AM
BrandonCause
Sep 14, 2015 10:41 PM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
