What grease to use for Starter
Old Dec 6, 2005 | 08:57 PM
lefty
Going to re-grease my starter tomorrow. Which type of grease do you guys use? Went to a local auto store and they told me to use Di-electric grease. I read the packaging and it was illustrating its use on SparkPlugs.
Is this ok or is a High temp grease needed?
Old Dec 6, 2005 | 09:05 PM
BigLou93SE's Avatar
The grease that I used, as well as motorvate.ca if I remember correctly is White Lithium Grease.
Old Dec 6, 2005 | 09:26 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
I used some teflon synthetic grease i had lying around. It's been working fine for months. The starter grindng has gone away completely.
Old Dec 7, 2005 | 04:54 AM
njmaxseltd's Avatar
Di-Electric grease is for electrical components. The part of the starter your greasing is mechanical. Hi temp wheel bearing grease should do just fine.
Old Dec 7, 2005 | 08:31 AM
ManualMaxima's Avatar
5th Gen till she dies!
i am going to do this......wheel bearing grease is the way to go? if so that is what i will be doing, my starter is making a horriebale noise..
Old Dec 7, 2005 | 10:30 AM
PLUMMAXSE's Avatar
I used a synthetic grease from Walmart. Looks red in the can for about $5 bucks. Regreased about a year ago. So far, so good!!
Old Dec 7, 2005 | 12:39 PM
lefty
thanks dudes...not too sure why the guy told me dielectric grease.. he did say that the starter is an electrical componenet. Now I am not a mechanic but it sounded odd to me.
Will use some synthetic white grease.
k.
Old Dec 7, 2005 | 12:52 PM
Mishmosh's Avatar
He probably thought you wanted to dab some on the terminals. I used bearing grease in the tubs myself.
Old Dec 7, 2005 | 01:53 PM
MaxMateo5's Avatar
Can you grease a starter with it on the car?? or does it have to be removed... I just replaced one but need to regrease the other car... thanks
Old Dec 7, 2005 | 05:55 PM
Dan's Avatar
Dan
it definitley has to be removed. You are basically dissasembling the whole starter. See the motorcate.ca instructions.
Old Dec 7, 2005 | 06:49 PM
f550maranello2's Avatar
White Lithium Grease is what i used
Old Dec 7, 2005 | 06:52 PM
lilaclucymaxima's Avatar
Team Ramrod
on the white lithium grease.
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
Bonka
Sep 14, 2015 11:18 PM
SusieQQ
Sep 9, 2015 12:14 PM
