What's the optimum launch RPM for 4th gen?
going drag racin' tomorrow before i get the SC in, to see what times im getting.prolyl gonna run full interior and what not. i dont really car for the quarter mi, but i just wanted to have a "well rounded" maxima. hehe.
Re: All depends on traction
Originally posted by Confused
if you can launch at 4k your there,,,, you might want to start at 2k and work your way up.
Originally posted by Synki
You guys do know he's auto right?
To get the best et, you must be coming off the line above 3500rpms which means you need to wind it up to 4K. Quickly slip the clutch and feed it gas slowly until you feel it hook up and then go WOT. What wheels you gonna run?
I'm excited that you're going to the track to test out the ECU. Is Nabil going? Even if your ets are a bit slow, the trap speed should be a very good indicator of potential et with a good 60'. Good luck.
I'd shift at these rpms as indicated by the tach:
1-2 6500
2-3 6200
3-4 6000
Dave
Cheston and _DRU_ have the fastest Max's every built *sheesh* its nissan's untold secret.. the 97 5spd GXE
You guys do know he's auto right? Unless you have a high stall tq converter. For dragging, i usually launch anywhere from 1.7k - 2k rpms depending on traction.
on wednesday, I was launching between 2000 and 2500 and poping the clutch, letting off the gas for just a moment to grab traction then flooring it. Tire pressure is critical to a good launch. I got a 2.191 on street tires doing this.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
