Changing SC pulley??
Old Aug 31, 2006 | 08:51 PM
Kenny302's Avatar
How do I change the pulley on a SC? Want to take out the stock pulley and put in a 3.125, how do I do it. The SC is already out, so how do I get the pulley off the SC?
Old Aug 31, 2006 | 09:10 PM
BlackCat's Avatar
RIP '98 Maxima SE
You'll need a pulley puller to get the current pulley off the spindle.
Old Aug 31, 2006 | 09:14 PM
matty's Avatar
They kinda get frozen on there. Sometimes you can just pull them off, sometimes not. Youll need a pulley pulley or just a screw driver wedged in between the pulley and the blower, but be gentle.
-mat
Old Aug 31, 2006 | 09:19 PM
Kenny302's Avatar
what about the screw?
Old Aug 31, 2006 | 09:24 PM
matty's Avatar
Take it off. Impact wrench, or get one of those Sears Oil wrenches, the rubber ones, and go the other way on the pulley with it as you loosen the bolt.
-matt
Old Aug 31, 2006 | 09:45 PM
Kenny302's Avatar
Thanks Alot.... I'll give that a try in the morning.........
Old Sep 1, 2006 | 08:22 AM
vortechpower's Avatar
To unloosen the screw you will need an socket (14mm) to hold the impeller side so the pulley will not freely spin while you try to loosen it. If you try to use a screw driver you will probably ruin the pulley. Go to sears and get the pulley puller, I was a initial skeptic but damn its worth it. Its like try to spread peanut butter with your finger or a knife. A little bit of wd-40 always helps to loosen things up.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
RWCreative
Sep 21, 2015 11:01 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
