brake booster check valve question
Old Nov 19, 2006 | 06:01 PM
larryseibel's Avatar
my search funtion is down right now for some reason so i dont know if this is a dumb question but i was wondering if i need a check valve for the power brake booster? i dont want to pressurize the unit for a few reasons
1. power brake failure
2. damaging the seals in the booster or master cylinder
3. loosing boost pressure and hp
do the tt 300z have one we can use?
Old Nov 19, 2006 | 06:35 PM
95turbo gxe's Avatar
iirc the brake booster has a check valve. Someone correct me if im wrong!
Old Nov 19, 2006 | 06:43 PM
matty's Avatar
It has a check valve. Just connect it to the manifold and your set
-matt
Old Nov 19, 2006 | 07:32 PM
thanks!!!!!!
Old Nov 21, 2006 | 05:17 PM
Alex_V
IIRC some one had a problem with boost leaking into the booster. They used 2 from a turbo supra and that solved the problem.
~Alex
Old Nov 21, 2006 | 09:53 PM
Nealoc187's Avatar
SLOW
MikeD had this problem - when going to the brake immediately after being in boost at the track = no brakes. Replaced the check valve, problem went away.
Old Nov 24, 2006 | 05:43 AM
I30tMikeD's Avatar
Nope, your wrong. Problem was never fixed
Old Nov 24, 2006 | 01:33 PM
Nealoc187's Avatar
SLOW
Oh I thought you replaced that check valve.
Old Jun 10, 2019 | 08:02 AM
Jennifer Daugherty's Avatar
-matt
Where is the brake booster check valve at? I can't find it around the manifold, and I'm totally stumped!!!! I nade a new thread about this issue just incase. Any help is apprechiated!!! Tia!!!!
Old Jun 10, 2019 | 10:57 PM
Fakie J Farkerton's Avatar
It has an arrow on it
Follow your brake booster tubing it's in the middle-ish
Old Jun 11, 2019 | 07:24 AM
Dang it!!!! Does it go into the manifold or not?!?!?!?!?
Jennifer Daugherty
Jun 10, 2019 08:55 PM
Tino98max
Aug 9, 2005 01:29 PM
Julio
Jul 22, 2004 02:14 PM
