2 questions..DRL's and rubbing
Old Nov 26, 2006 | 10:58 PM
ke.max's Avatar
Hey..
I have 2 questions for you guys..
1) Is there any way to disable your high beams as your DRL's? I was looking at my friends Audi the other day, and I much like the fogs as the drl's. It looks very good, and I'd do anything to be able to drive with just my fogs on..no highs as DRL's.
2) I have a chance to pick up some winter rubber..225/60/16 for very cheap..on steelies. Will those rub on a 5.5 gen?
Old Nov 27, 2006 | 08:30 AM
M1RAG3's Avatar
1) Rewire fog lights: http://www.innerbean.com/housecor/fog_rewire.html
To disable DRLs go to the fusebox inside the cabin and remove the fuse labelled "DTRL"
2) No. They wont rub on OEM suspention....are you lowered though?
Old Nov 27, 2006 | 10:26 AM
ke.max's Avatar
Nope, not lowered
Thanks for the info!
Old Apr 7, 2008 | 11:51 PM
hotstartup's Avatar
bumping an old thread, I have a 2003 max, i looked at the in cabin fuse box, no DTRL fuse in there. any other method of doing this, or am i missing something.
Old Apr 8, 2008 | 07:06 AM
mist max2000's Avatar
did you go to the houscore website as posted above?.. the fuse is not in cabin it is passenger side behind the headlight on the passenger quarter panel..
Old Apr 8, 2008 | 07:34 AM
hotstartup's Avatar
" To disable DRLs go to the fusebox inside the cabin and remove the fuse labelled "DTRL" "
I just read that part as i did not want to rewire to the foglights
Old Apr 8, 2008 | 10:31 AM
M1RAG3's Avatar
My maxima is a 2000 Canadian spec and the fuse is, in fact, in the cabin fusebox.
I am thinking that the fuse was either a) repositioned in forthcoming models (2000> ) or b) is located in a different place in US spec models. I thought that US models didnt have DRLs though? correct me if im wrong because I thought DRLs were only mandated in Canada?
Old Apr 8, 2008 | 11:47 AM
sergey85's Avatar
you might have the auto option or the low beams on maybe
Old Apr 8, 2008 | 08:54 PM
hotstartup's Avatar
i do have auto headlights but i thought the fuse shuld still be there in the cabin.
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
MikesChevelle
Aug 7, 2015 05:57 PM
RealityCheck
Aug 5, 2015 06:18 AM
Bucktown
Mar 20, 2001 06:18 PM
