Wierd Noises after header install
Old Mar 24, 2008 | 05:40 PM
eyecon7's Avatar
Ok after i installed my headers back in Jan. Ive had real rough idling and when at WOT Smoke comes out of my tail pipe. Not Consistently just when it drops down to second. And when i am cruising 2000 rpms or so... it feel like my manifold is loose.. sounds like a metallic Noise.. like when the car runs on 87...I looked over
the headers everything seems to be tight including the Y pipe.. i havent had the chance to go over it with a Wrench..
Old Mar 24, 2008 | 05:45 PM
slickrick's Avatar
b pipe rattling anywhere?
Old Mar 24, 2008 | 05:48 PM
eyecon7's Avatar
dunno i have to check that. Damn car is too low wont fit on jack stands soo i always have to go to the shop.
Old Mar 24, 2008 | 05:50 PM
slickrick's Avatar
whats your exhaust setup consist of?
Old Mar 24, 2008 | 05:51 PM
eyecon7's Avatar
stock after y pipe....
Old Mar 24, 2008 | 05:56 PM
slickrick's Avatar
hmm then I'm guessing the b-pipe might not be the issue. HS headers?
Old Mar 24, 2008 | 06:00 PM
Puppetmaster's Avatar
Is the front manifold hitting the AC line up front? I know the Hotshots come really close and in some cases the AC line is even in the way.
Could you provide a more detailed description of the noise?
Not sure about the rough idle, and I'm guessing the smoke is either because you're running rich or burning oil or coolant. May or may not be related to the headers, since there are many factors involved here.
Old Mar 25, 2008 | 06:45 AM
eyecon7's Avatar
yes
Umm this is going to be hard...ok remember the heat shield we have on our stock headers.. well picture that dragging but when you go pass 2k it goes away.. it happens like the knock noise...with gas....
Old Apr 8, 2008 | 05:13 PM
eyecon7's Avatar
My CEL Light Went off and my Secondary o2 Sensors are not plugged in....is there a reason y..Just noticed it today...Will it come back???
Old Apr 8, 2008 | 05:41 PM
slickrick's Avatar
did you pull the codes before it went off?
Old Apr 8, 2008 | 08:57 PM
eyecon7's Avatar
No but i kno its the o2 casue they only came on once i installed my headers.
MaxLife17
Jun 27, 2019 01:37 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
