HELP!! VE5spd
Old May 12, 2007 | 05:12 PM
mofoaka's Avatar
HELP!! VE5spd
can someone please post up the KS bypassing pictures? i'm not sure how to place the resistor. i need to test out the KS. i've already checked for codes and the ECU says 55 so all is normal. but i still suspect the KS. i replaced my coil packs already. but it seems like my spark plugs have a bit of oil residue on the top.. in the front i have oil inside next to the spark plug.. is that normal? or do i have a leaking valve cover? VTC's have been rebuild before also. thanks!
Old May 12, 2007 | 05:22 PM
Greeny's Avatar
¯\(°_o)/¯
What is the car doing?
No power below 3500rpm?
The oil on the plug tops is a bad valve cover gasket..
Old May 12, 2007 | 07:09 PM
mofoaka's Avatar
yea no power under 3500, i would hope to fix the car under 300 bucks... or else my parents will donate the car.. i have a mazdaspeed 6 as a daily.. this is really just a project car =) this was also my very first car so i wanted to keep it in the family
Old May 12, 2007 | 07:22 PM
Cliff Clavin's Avatar
Way out West
the knock sensor will just make your car feel like it has less power, usually when the car is hot/been running a long time (heat soak).
Please be more specific as to all of the symptoms.
Old May 12, 2007 | 07:29 PM
mofoaka's Avatar
car wasn't heat soaked, there is actually lack of power throughout the whole powerband. i've checked all the sparkplugs, coil packs, and MAF. everythiing is good it does feel as though the ecu is in safemode. i really wanna know exactly how i do the bypass so i can test the KS
Old May 12, 2007 | 08:00 PM
Way out West
old thread on KS bypass
try that.
Old May 12, 2007 | 08:49 PM
mofoaka's Avatar
thanks i will try that out first and see if that helps if its the KS i'll replace it and the valve cover gaskets
Old May 12, 2007 | 10:44 PM
mikekantor's Avatar
Hey look, a fellow houstonite!
Would a bad KS constantly send a knocking signal, or fail to detect a knock when it finally occurs?
It does sound like your valve cover gasket is leaking oil, it may also have a vacuum leak in another damaged section of the gasket and that could be the problem.
Old May 13, 2007 | 08:33 AM
Matt93SE's Avatar
STFU n00b!
Bad knock sensor will fail to send any signal at all.
when the engine doesn't see any resistance where it should for the sensor, it assumes the thing is bad and runs in a 'failsafe' mode, pulling back the timing to a point the ECU knows is safe.
Old May 20, 2007 | 09:28 PM
magobiasso's Avatar
already adjustment the problem?
Old May 31, 2007 | 03:38 PM
mofoaka's Avatar
just got a free 470komh 1/2 watt resistor imma put it in tonight and drive around
Old May 31, 2007 | 04:25 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
remember to use the highest octane you can get (91-93) before driving with a bypassed knock sensor.
Old May 31, 2007 | 05:38 PM
92 Max's Avatar
Could it be the power valve not opening? I assume the lack of power happens when accelerating?
Old May 31, 2007 | 06:12 PM
James92SE's Avatar
2 VE's are better than one!
Already adjustment the problem?
Old May 31, 2007 | 08:18 PM
mofoaka's Avatar
i put it in, i put 2 470komh resistors .. i didnt notice much of a difference.. i did notice a cracked coil pack in the front.. i took out the resistor again and felt no difference. what's this about the power valve? how do i know if its working? either way i need to replace the knock sensor .. because i have 2 leaky valve covers.. so i need to reach the back valve cover to replace the seal any other suggestions?
what does already adjustment the problem? mean?
Old Jun 1, 2007 | 06:23 AM
only put in 1 resistor... putting in 2 in parallel halves the resistance overall. putting in 2 in series doubles it.
'already adjustment the problem' is a phrase borrowed from magobiasso, because his english isn't very good, and he was just trying to get 15 posts to make his own thread... he posted that phrase in like, 15 different threads, to get his post count up. Equivalent to "did you fix it yet?" basically, it's just to be funny.
Old Jun 1, 2007 | 06:45 AM
Matt93SE's Avatar
STFU n00b!
Look where the guy's from. English is probably not his first language. I'm going to assume he was asking if you've fixed the problem since it was a week since the last post in the thread.
Old Jun 1, 2007 | 07:31 AM
yeah i know where he's from, and that spanish is definitely his first language. James just reused the phrase (which is rather catchy if you ask me) for some comic relief. but mag posted that phrase in at least 5 threads, so that's why i said he was using it to get his post count up to post "no arranca en frío"
Old Jun 2, 2007 | 02:27 AM
maximagician's Avatar
[QUOTE=mofoaka]i put it in, i put 2 470komh resistors .. i didnt notice much of a difference..
are the resistors one way/
meaning can they be put in backwards? (which terminal on the k.s. harness to which wire off the resistor?)
Old Jun 2, 2007 | 08:03 AM
James92SE's Avatar
Yeah, the guy has said the same thing in about 193424354254 threads
mrkanda
19
Aug 13, 2008 12:28 PM
mrkanda
Jul 19, 2008 07:57 PM
DMad8724
Oct 1, 2005 07:01 PM
DMad8724
Jun 15, 2005 09:17 AM
DMad8724
57
Mar 18, 2005 05:59 AM
