So I got a new problem...
Old Aug 12, 2007 | 11:10 AM
nForce's Avatar
The Computer Guy
So I parked my car in garage after I went to drop my lil brother off at work and as I was about to leave again I look at the garage floor and found a puddle of tranny fluid I inspected it closer and found it to be coming from the drivers side axle area. The axles and seals are new and as you all probably know the issues I have had with trannys so this makes me a little frustrated.
So here is what I am thinking happened..
  1. Axle needs to be re-seated
  2. Axle seal went bad needs replacement again (I bought nissan ones when I did the trany swap)
  3. Extreme hot weather has affected my seal and is causing it to expand and leak (It has been 100 + for past 6 days straight)
What do you all think?
Old Aug 12, 2007 | 03:15 PM
Greeny's Avatar
¯\(°_o)/¯
Nut loose behind the steering wheel?
How big is the puddle?
Check for loose steering/suspension components on that side(axle may have partially come out)
It may just be a gouged seal,in that case,buy another seal and be very careful when reinstalling the axle again.
Old Aug 12, 2007 | 04:05 PM
nForce's Avatar
The Computer Guy
I let my car sit for past couple hours and it seems it has leaked about about half quart of fluid.. I am gonna go inspect it closer to veifiy if it really is the axle or something else.
Old Aug 12, 2007 | 04:43 PM
nForce's Avatar
The Computer Guy
After a close look the drivers side axle seem to have some how popped out. It had two finger lengths of space before it touches the tranny, I was able to feel the spindle . Can the alignment shop be blamed for this? I had it aligned 4 days ago weird that it happened after I took it to them…
Old Aug 12, 2007 | 05:04 PM
Greeny's Avatar
¯\(°_o)/¯
Hmmmm...
Do you have camber bolts?
Old Aug 12, 2007 | 05:34 PM
Hectic's Avatar
I think I jinxed you by asking how the tranny is holding up
Driver side axle is no biggie. Pop it back in, secure the strut and replace the axle nut. Make sure you've got a cotter pin in there, there probably isn't one and the nut came loose.
Old Aug 12, 2007 | 06:08 PM
nForce's Avatar
The Computer Guy
Ok guys just fixed it, I poped the axle back in and filled the tranny up. Shes good as new
I do have camber bolts installed because none of the shops could properly align my car so a camber kit was there solution...
Old Aug 12, 2007 | 06:09 PM
nForce's Avatar
The Computer Guy
Alll I did was removed tire and axle nut and it slid right back into place. What would have caused it to pop out?
Old Aug 13, 2007 | 12:04 PM
nForce's Avatar
The Computer Guy
Anyone have and idea why it popped out? Is the shop responsible for it?
Old Aug 13, 2007 | 12:21 PM
Greeny's Avatar
¯\(°_o)/¯
Do you have a retainer clip on the end of the axle?
Old Aug 13, 2007 | 12:22 PM
nForce's Avatar
The Computer Guy
Yea the nut didnt move at all it was tight when I removed it.
Old Aug 13, 2007 | 12:25 PM
Jeff92se's Avatar
I'm needing a caw
^^ +1. Or the circlip is worn. I usually have to jam the axle in/out like I'm humping an elephant.
Old Aug 13, 2007 | 12:37 PM
Greeny's Avatar
¯\(°_o)/¯
Mind visual.
Old Aug 13, 2007 | 01:59 PM
nForce's Avatar
The Computer Guy
Mind visual.
people next door probably thinking your have with your maxima
Old Aug 13, 2007 | 02:10 PM
Greeny's Avatar
¯\(°_o)/¯
Actually,i think they do think that..
nadir_s
Apr 15, 2003 09:51 PM
Cabowabo
Dec 11, 2002 02:02 PM
nadir_s
Jul 23, 2002 01:11 PM
lorddeceiver
Aug 6, 2001 06:23 PM
