So I got a new problem...
So I parked my car in garage after I went to drop my lil brother off at work and as I was about to leave again I look at the garage floor and found a puddle of tranny fluid I inspected it closer and found it to be coming from the drivers side axle area. The axles and seals are new and as you all probably know the issues I have had with trannys so this makes me a little frustrated.
So here is what I am thinking happened..
What do you all think?
- Axle needs to be re-seated
- Axle seal went bad needs replacement again (I bought nissan ones when I did the trany swap)
- Extreme hot weather has affected my seal and is causing it to expand and leak (It has been 100 + for past 6 days straight)
Nut loose behind the steering wheel?
How big is the puddle?
Check for loose steering/suspension components on that side(axle may have partially come out)
It may just be a gouged seal,in that case,buy another seal and be very careful when reinstalling the axle again.
After a close look the drivers side axle seem to have some how popped out. It had two finger lengths of space before it touches the tranny, I was able to feel the spindle . Can the alignment shop be blamed for this? I had it aligned 4 days ago weird that it happened after I took it to them…
Hmmmm...
Do you have camber bolts?
Driver side axle is no biggie. Pop it back in, secure the strut and replace the axle nut. Make sure you've got a cotter pin in there, there probably isn't one and the nut came loose.
Ok guys just fixed it, I poped the axle back in and filled the tranny up. Shes good as new
I do have camber bolts installed because none of the shops could properly align my car so a camber kit was there solution...
Originally Posted by Hectic
I think I jinxed you by asking how the tranny is holding up
nadir_s
04-15-2003 09:51 PM
Cabowabo
12-11-2002 02:02 PM
nadir_s
07-23-2002 01:11 PM
